Any downsides going wet plate to nozzle?
They are very cheap and vesitile, i think i could possibly stealth my setup, by mounting it underneath my intake tract.
Otherwise, are there any other options for a wet kit on a 102 tb?
Dont plan on spraying more than 150 btw.
http://nitrousoutlet.com/catalog/pro...7&product=4111
http://nitrousoutlet.com/catalog/cat...=14§ion=37
Nozzle is to just make sure the placement of the nozzle when it sprays it get evenly distributed in the intake. Nitrous Outlet also makes the money maker kit which hides the nozzle and noids.
For no more than a 150 shot I would prefer a nozzle to begin with.
If you are concerned about lean spikes, make sure that both your nitrous and fuel lines from the solenoids are short (preferably with the fuel line being shorter than the nitrous line if you are exceptionally concerned about lean spikes). Also, some companies make controllers (the HSW interface is the one that comes to mind immediately) that can delay the nitrous solenoid in order to ensure that the fuel and nitrous reach the intake at the same time (this may be what you meant by progressive).
Of course, the info above is only useful if you actually have a lean spike, all may work well. Be sure to have the right plugs and a good tune (read: learn to read your plugs and do it often to see what the motor wants). This is especially important with a stock bottom end car if you want it to live.
Sorry I keep editing this... You're also probably going to want to add a second pump in the tank or throw a stand alone in the car.
If I weren't using my stand alone I'd be running a -8 AN feed from the tank, through my Summit rails with a -8 crossover, to a -6 return to a regulator in the front of the car using the stock feed as the return.
If it all comes off of the rail, I'd be worried about the rear mounted regulator moving fast enough.
BTW, you'll have to be very concious of the tune and what the car's doing to keep the stock bottom end living, especially if you bump the shot up anymore. Get tuning software to be able to log all of your passes, look at the plugs, and be able to make educated adjustments based on what your data is telling you.
Does the thing run good? Any races won against cars that dyno'ed significantly higher?
I don't mean to bust you ***** about this, I just want to make sure everything else is mechanically sound before you go spray the car hard.
Edit: Sorry I missed the part about no track times.
My last setup t56, ms4 and 150 car only made 508rwhp on this same dyno and a lot of people said the same thing bout that being low but didnt understand the type of dyno i was using. I never got a chance to go put it on a dynojet for my bragging rights hp numbers before it blew up.
heres a sheet from the last setup n/a and on 150 shot:
If it runs good with other cars that should make similar power, that's all that matters!!!!
BTW - What was up with that second dyno you posted???
