Dry plate and NANO question
Old Aug 22, 2010 | 06:50 PM
C5Munch's Avatar
Default Dry plate and NANO question
Been lurking the nitrous section for over a year now and I have to say this place is a wealth of information. I've finally decided to put nitrous on my Vette and have a few questions before I actually install it so here's my first.
I ordered the HSW dry plate kit with the interface and am thinking about using the NANO. NANO recommends downsizing the jets 20%-25% when using their system so if I wanted a 100 shot I would jet for the 75. Would that mean that I would still set the interface for a 100 shot? I'm assuming yes but want to make sure. I think you'd have to set the interface, make a run and then check the AFR and plugs but I worry that if it's not really close the first try that I might break something.
Thanks.
Old Aug 22, 2010 | 07:02 PM
Brad@NANO Direct's Avatar
Everything stated is on target, let me know if you need help with your jet selection.
Old Aug 22, 2010 | 09:42 PM
C5Munch's Avatar
Thanks, I appreciate the input.
Old Aug 23, 2010 | 06:53 AM
Nick@HSW's Avatar
You should be fine but if need be you can always use the top end feature of the Interface to compensate for the pressure retention benefits of nano.
Nick
Old Aug 23, 2010 | 08:03 AM
Nick
Thanks for pointing that out Nick!
Old Aug 23, 2010 | 07:15 PM
C5Munch's Avatar
Nick
I'm confused. Are you saying that the Interface normally compensates for pressure loss in that it delivers less fuel as the run gets longer?
Never mind, I went and read the manual.
Old Aug 24, 2010 | 08:56 AM
Nick@HSW's Avatar
You sir are my hero! How can I get more people to do this?
