Plug readers, tell me if im right.
Old Aug 23, 2010 | 11:26 PM
green96ta's Avatar
Default Plug readers, tell me if im right.
going by the timing marks i need to pull less timing. my idle is rich, and my wot is good. am i right?
Old Aug 23, 2010 | 11:29 PM
dnkynrbk's Avatar
To read plugs Put fresh ones in then you need to make a pull then kill the motor then pull the plugs looks like you may have had it idling for a bit or drove around before pulling them.
Are these new plugs?
Old Aug 24, 2010 | 12:04 AM
03supercobra's Avatar
X2 need to see the plugs after a WOT pull, if you let it idle or drive it around they become useless!
Old Aug 24, 2010 | 06:48 AM
green96ta's Avatar
Default hmm
the plugs are two weeks old. im gonna put some new ones in today, but ill have to pull them after a pull at ltx shootout i guess. wont have time to untill then
Old Aug 24, 2010 | 07:12 AM
SargeZ06's Avatar
So what is the proper procedure for shutting the car down after a WOT pass? Turn the ignition off with you foot still in the throttle or let off and do it immediately after you lift?
Old Aug 24, 2010 | 07:23 AM
dnkynrbk's Avatar
If you can get someone with a cart or 4wheeler to pull you. I would make a hit down to the 1000ft. and then just let off the gas kill the motor then coast to the return road some tracks have a return road past the 1000ft and one at the end of the 1/4 depends where you are at. If you have a close tune you can do it all the way down the track then shut it off at the end. Good luck keep us posted.
Old Aug 24, 2010 | 10:07 AM
X2 and if you don't have someone to pull you back, shut down the car after your WOT pass and coast it off the track to a safe area, and have a couple extra plugs in yours car, with ratchet and socket, swap out a couple plugs, make sure one of the plugs that you pull is #7. Then you can drive back to the pits and have a look.
Old Aug 24, 2010 | 11:57 AM
SargeZ06's Avatar
That's an excellent idea about the extra plugs. Thanks all.
Old Aug 25, 2010 | 12:00 AM
No problem!
Old Aug 26, 2010 | 03:54 PM
Chris@NitroDaves
Guest
Posts: n/a
Couldn't have said it better...Good post's
Old Aug 26, 2010 | 04:30 PM
Dirty Vegas's Avatar
The only issue I see with that is putting cold plugs into a hot head. I was always told to never do that, since once the heads cool and contract, the plug will be seized. Am I wrong here?
Old Aug 26, 2010 | 04:58 PM
ryarbrough's Avatar
I've never had problems, but I've always used antisieze too...
Old Aug 26, 2010 | 07:40 PM
Nope, never had problems here either. There are many guys who do plug changes in between rounds when the motor is still pretty hot.
