nano question
Old Aug 29, 2010 | 03:48 PM
JUICED01's Avatar
Default nano question
im thiunking about buying a nano was just looking for some input
Old Aug 29, 2010 | 05:12 PM
Firehawk441's Avatar
I use it for the constant bottle pressures in the colder months without the use of a bottle warmer...
Old Aug 29, 2010 | 11:20 PM
itsslow98's Avatar
for me i love it during the cold months but the summer time is useless for me, literally. I daily drive my car and leave the bottle in the car so if the nano is hooked up the pressure is way too high due to the heat of the bottle already. nitrous bottles must be 80 degrees or lower for the nano to be in the correct operating temperature. You can ice the bottle down at the tracks and it works perfect but if you plan to use it on the fly, better hope its not 100 degrees out.
Old Aug 29, 2010 | 11:47 PM
danger ds's Avatar
I like the performance edge it provides but hate the 40min drive to get it filled.
Old Aug 29, 2010 | 11:50 PM
Squirts11's Avatar
More or less, it's a pusher system that helps keep bottle pressure constant during a run. Bottle pressure often drops significantly during a full 1/4 mile pass, and the nano eliminates the drop in bottle pressure.
Old Aug 30, 2010 | 06:29 AM
jdaniel's Avatar
I got rid of mine because there was no where to fill it. I was a little pissed because Cartek led me to believe that you could fill it anywhere at any time. Thats the only reason I went nitrous in the first place instead of FI. Im glad I did it anyways despite the hard time with NANO. I personally wouldnt recommend it to anyone just because of the filling situation.
Old Aug 30, 2010 | 09:32 AM
panterx1's Avatar
I have the NANO 3000. I get it filled up a mile from the house at a paintball place. I haven't run it at the track so I can't speak to its performance yet.
Old Aug 30, 2010 | 09:37 AM
kinglt-1's Avatar
get A 3000PSI kit... alot more options are out there for filling it. it's kind of hard to find a place to fill a 4500 kit.
Old Aug 30, 2010 | 11:20 AM
Brad@NANO Direct's Avatar
If you want send me your zip code and i'll do some fill searching for you.
We use, Fire and Safety, freinds at the fire dept, welding supply, scuba and paintball places.
Old Aug 31, 2010 | 12:53 AM
itsslow98's Avatar
I tried the first two places recommended and they couldnt do it(3000 kit), found a scuba shop and first trip they wanted to inspect teh bottle(remove the valve) for 15 bucks and another 8 to fill it. Then another 8 every fill. If the prices of nitrous dont kill me that will. So im done with it till its winter and I dont spray much.
Old Aug 31, 2010 | 07:45 AM
I am very sorry about this. Next time have them give us a call so we can give them the DOT certification. Usually it costs between $2-4 to have them filled.
Old Aug 31, 2010 | 08:20 AM
99_Z_155's Avatar
If you have the money, get it for the elimination of heater hassle. yeah, when its warmer no big deal, but when it cools off a bit, BAM, pressure instantly. i hated my bottle heater days.
Old Aug 31, 2010 | 03:48 PM
GMMillwright's Avatar
I haven't had any issues with getting my 4500 kit filled. I tried a local dive shop first, but they didn't have the right fittings. Local paintball store charges me $5 a fill. They always ask what it's for, though. I bought it for the constant pressure and it's benefits in the last 1/8.
Old Aug 31, 2010 | 06:53 PM
kinglt-1's Avatar
pm me paintball shop u use please? Thanks!
Old Sep 1, 2010 | 08:51 AM
Give me a little time today and i'll do some searching for you guys.
