NGK spark plug ?
NGK spark plug ?
Hers the deal I always use ngk br7ef plugs,I accidently picked up ngk br7efs plugs noticed they are a little diff the tip on the br7ef has a grove the br7efs does not.Should I use these plugs?or should I go what i've been using.
I used that plug for my motor tune only, and then I used the b8efs plug for the jug without any issues. I even sprayed on that extended plug a couple times by accident without any issues. But then again spark plugs are cheap
