Nitrous newbie needing recommendations on a few things...
Old Sep 20, 2010 | 12:30 PM
02_Z28_G's Avatar
Originally Posted by kdavis
Is the guage electric? If not wouldn't you need to run a line to it from the bottle?
the gauge i am not to sure about...my friend is giving it to me and i believe right now it is hooked up directly to his bottle so i'm guessing i would have to go the route of running another line to mount the gauge inside to the switch panel i am making.
nitro dave - thanks for the info. i will probably give the fpss a try an
Old Sep 20, 2010 | 01:19 PM
Nitro Dave's Nitrous Outlet's Avatar
No problem. Let me know if you need some pointers on how to adjust it.
Dave
Old Sep 23, 2010 | 11:53 AM
02_Z28_G's Avatar
if i purchase this bottle heater would i need another adapter for the fpss or would the dual one that comes with this work?
http://www.dynotunenitrous.com/store...p?idproduct=17
Old Sep 24, 2010 | 04:37 PM
If you are saying you did not use it with the heater and want to know if you can use it at the fuel rail instead, yes you can.
Dave
Old Sep 29, 2010 | 03:13 PM
02_Z28_G's Avatar
how would i go about running these with each other?
http://www.rpmoutlet.com/pdf/zex82085.pdf
http://www.dynotunenitrous.com/store...TCH%20FPSS.pdf
being that the traction control switch seems like it need a relay would i still need to add one to the fpss?
Old Sep 29, 2010 | 04:51 PM
The fpss will break the ground to pin 86 on the relay.
Old Sep 30, 2010 | 09:53 AM
02_Z28_G's Avatar
so i would have to run seperate relays...?
