Nitrous newbie needing recommendations on a few things...
Old Sep 13, 2010 | 03:56 PM
02_Z28_G's Avatar
Question Nitrous newbie needing recommendations on a few things...
I have ordered my first nitrous kit and it should be here sometime this week. Does anyone have any suggestions as to where i could mount the bottle in an 02z28? I would like to keep it hidden so i was thinking the area where the spare tire is located...
Also would it be better to run the lines on the outside of the car or can i run them on the inside?
thank you for any help
Old Sep 13, 2010 | 04:15 PM
A-Body's Avatar
Spare tire well seems to be a favorite by many f-body guys, as for running lines, do not run them inside the car any half-awake tech inspector should not allow you to run. Some people do run the lines inside the car However I highly recommend you run them under the car parallel with a fuel or brake line (in split loom). And please don't forget the down-tube!
Old Sep 13, 2010 | 04:18 PM
Carter01's Avatar
try this link https://ls1tech.com/forums/nitrous-o...t=mount+bottle
also make sure you swap those tr55s out to the correct heat range before spraying the car. good luck
Old Sep 13, 2010 | 04:20 PM
02_Z28_G's Avatar
ok well looks like i got the mounting location set.
only reason i asked about running the lines is because i've read a couple of installs that do and it just seemed awkward to do that. Everything will be covered in loom seeing as how i want to keep it as hidden as possible. My only question was with running it on the outside is the line more suseptable to rust/other weather problems?
The kit had been ordered for now. I will be purchasing the blow down tube, bottle heater, and other accesories with my next paycheck.
Old Sep 13, 2010 | 04:21 PM
02_Z28_G's Avatar
i have read that since i don't have much done the tr6 will work fine or would you suggest the br7ef?
Old Sep 13, 2010 | 04:41 PM
Carter01's Avatar
Always use a non-projected tip plug. Like br7ef or br8ef etc.. I think they make the 6 in non-proj also. Post up all mods and what hp level you plan on spraying so we can get you the right plug.
Old Sep 13, 2010 | 04:45 PM
02_Z28_G's Avatar
Well it would be the mods i have in my sig plus the nitrous dry kit and i only plan on spraying a 75 shot for now. I don't plan on spraying it much, maybe once a week or if I happen to make it out to the local drag strip but even at that I usually only make 2-3 passes
Old Sep 13, 2010 | 05:03 PM
Carter01's Avatar
With no cam the br6efs would be fine at 75, if you go above 100 with your current setup then I would switch to br7efs.
Old Sep 13, 2010 | 09:06 PM
justinj's Avatar
just finished mine last weekend!
Attached Thumbnails Nitrous newbie needing recommendations on a few things...-dsc02686-resize.jpg
Old Sep 14, 2010 | 10:36 AM
02_Z28_G's Avatar
that's the tr6...?
justin j - i like the set up.
i've heard something about an 860 bracket...has anyone else heard of this?
Old Sep 14, 2010 | 01:37 PM
justinj's Avatar
that's the tr6...?
Heated Bottle Bracket? http://www.860performance.com/catalo...38&section=119
You would still need a spare tire plate to do that set up still.
Old Sep 14, 2010 | 02:18 PM
Carter01's Avatar
that's the tr6...?
tr6 is projected tip, br6ef is non-projected tip but same heat range. there is a good write up about the difference, just search it. it will make alot more sense after seeing the comparison on how far the electrode sticks out compared to the non-pro tip.
I have the heated bottle bracket and it works great!
Old Sep 17, 2010 | 12:45 PM
02_Z28_G's Avatar
would this be the brackets i would need to put the bottle in the spare tire area?
http://www.860performance.com/catalo...17&product=522
Old Sep 17, 2010 | 01:00 PM
ryarbrough's Avatar
You are correct!
Old Sep 17, 2010 | 04:36 PM
02_Z28_G's Avatar
ok...well i got the plate/bracket ordered now question is...with a dry system is a fpss needed?
Old Sep 17, 2010 | 04:39 PM
Nitro Dave's Nitrous Outlet's Avatar
The fpss is cheap insurance if the fuel pump were to fail. You would just put it off the fuel rail and cap it off. In the event the fuel pump fails it will kill the ground to the relay.
Dave
Old Sep 18, 2010 | 09:07 AM
02_Z28_G's Avatar
Dave
i've read of some people having problems with it shutting it off earlier than what it is set to. how would i make sure this doesn't happen? and this only shuts off the nitrous correct?
Old Sep 18, 2010 | 05:15 PM
02_Z28_G's Avatar
also...how would i go about mounting the bottle pressure gauge inside the car?
i am making a custom switch panel so it would go attached to that
Old Sep 19, 2010 | 04:22 AM
kdavis's Avatar
Is the guage electric? If not wouldn't you need to run a line to it from the bottle?
Old Sep 19, 2010 | 10:46 PM
The issue would be because they did not have the switch set properly. If its set properly you will not have an issue.
Dave
