What is the nitrous record for a 100% stock internal LS1?
#50
I went 11.19s on stock bottom end, stock cam, stock heads, stock ls1 intake, stock rear end with 3.23s.. Only weight reduction was back seats removed and skinnys up front on 275/50/15 et street radials.. 133k miles and heads never been off the car. This was on a 125 dry shot through my slp lid.
#51
I was under the impression that the most you want to spray through a stock short block (stock mains and rod bolts too!) is a 150 shot. What needs to be done to spray higher then 150? stand alone fuel system and progressive switch? would you have to spray say a 100 shot out the whole and gradually progress to lets say a 200 or 250 shot.
#52
#53
Anything over 150 and you'll need to upgrade your fuel pump for sure. I've sprayed 150 for many years and i've always sprayed it right off the line, no window switch or progressive controller but i'm also a stalled auto. If i were a 6spd car, i'd definitely have a window switch.
#55
I ran mid 10's with my old 1997 C5 A4 vette with an all original 120,000 + mile motor for 2 years straight. My mods are CF from 5 years ago (123sugey).
I started with a 125 wet shot and a 100 shot dry completely stock motor including injectors. Upgraded the nitrous system to a money maker 150 shot + the 100 dry shot and burnt a valve after the two years running the 225 shot.
