Worried!
If your tune is right and you use all the safety measures talked about on this site it's really not a big deal. 3000RPM and above and don't lug the car and you shouldn't have to worry about backfires.
I'm not ready to run it out of the hole at the track but on a roll I'm not worried at all.
few features: fpss, window switch, wot switch, correct heat range plug, nitrous filter, blow down tube etc..
What fpss is everyone running?
How often does fuel pooling/backfires occur on wet plate kits spraying in the 100hp range?
Hopefully not often, because I'll be running that same setup w/ nitrous outlet selenoids and plate.
The only time you have pooling is when you try and spray below 3k also set you tps at 3/4 throttle so you have to be well into it before it engauges.
I have the zex NMU for soleniod so hopefully it doesnt bypass or leak. It is set up below the plate so gravity should be at work here. That way if it does leak hopefully the fuel will clear out when it opens up before the system fires. Thats just my theory though I dont know if that would actually work.
