Just need some opinions.
Does everything look allright in the graph? I still can't get 150rwhp out of my 150 shot. but it's getting closer.. temp was 87 out today when I dyno'd. It's still really rich on the hit, is that normal on nitrous? I guess better rich then lean.
How much timing you running on the juice? Did you adjust the timing at all after making jet changes?
I'd drop down to a 34-35 jet and it'll pick up more power. Just guessing but I bet you end up around a 33-32 fuel jet.
FWIW on Harris plate with a .72N(200 shot) I'm running a 33 fuel jet and I only run 91 pump gas.
I did not adj. the timing when I made the jet changes. I only changed the jet from a .038 to a .037 then a .035... Im being told that 12.2 a/f is alittle lean on stock pistons,so for now I'll prob. put back in the .037 jet. That had me at a 11.7 a/f at wot. I did not have my tuner there today. I used the sniffer from the dynoshop along with my wideband and they were dead on together, but I do understand about reading the plugs, and I will read a couple def. on my next run. thanks for the input.
Just trying to understand the mindset. All of the controllers that have leanout or rich shut down all rely on the WB too.
Just trying to educate myself.
For example, I went by the wideband for a pull on mine, a/f showed great. Pulled the plugs, it was dead rich. Dropped a couple fuel sizes, graph cleaned up and still showed a nice a/f ratio.
That was the last time I did any tuning on the dyno.
