I made a plug run.
If it was mine I'd add a little fuel and make a pass, see how it likes that.
Then try another degree of timing.... it hasnt even burned the cadium all the way off the tip yet. I wouldnt even call that 1* on the strap.
They look ALOT like our last pass at the ORTC race timing wise.... very safe.
Try getting it to run around 12.5 -12.8 , you will also be able to put some timing in it once you get some fuel in there.
RPM graph looks good but it will pull alot harder with some fuel and timing in it.
