new to nitrous. what is this?
Old Oct 4, 2010 | 05:52 PM
Pennington55's Avatar
Default new to nitrous. what is this?
I just bought this kit off a guy from the forums. The wire comming out of this "thing" needed to be replaced. I started to mess with it and i pulled the wire completely out. Help me out and let me know if i need this part and where to get one. Thanks
I circled the part that the wire came out of.
Old Oct 4, 2010 | 06:00 PM
ttranssam's Avatar
looks like the purg noid
Old Oct 4, 2010 | 06:01 PM
ttranssam's Avatar
oh and there should be a power and ground....put it to a push button
Old Oct 4, 2010 | 06:35 PM
custm2500's Avatar
Ph.D. in HUBRIS
Education is what keeps you from making a bad name for nitrous!!! Make sure you are VERY educated before you hit the button. For you to have bought a kit and not know a purge solenoid tells me you need more education before you blow up your motor.
Not trying to be a jerk, just trying to make sure in a week or two you don't post a pick of motor parts and ask why.
Old Oct 4, 2010 | 07:19 PM
ryarbrough's Avatar
It's a purge solenoid. How much are you planning to spray on that? I see some things I don't like for a large shot.
Old Oct 4, 2010 | 07:39 PM
thanks for the help. it must of been the postitve wire. ill look into replaceing the solenoid. im not going for a big shot just a 75 or 100. Custm2500 i understand what your saying thats but why im reading the forums and asking questions.
Old Oct 4, 2010 | 08:34 PM
c6 batmobile's Avatar
purge solenoids dont have a power and ground per say. You can use either wire for either source. Just buy a new noid and you should be good to go.
Old Oct 4, 2010 | 08:47 PM
ryarbrough's Avatar
You could also open the solenoid up and solder a new wire on.
Old Oct 4, 2010 | 09:16 PM
custm2500's Avatar
Ph.D. in HUBRIS
Seems to be the case just wanted to drive that point home! Saves you money and the good record of nitrous. It is lots of fun just be carefull and kick some ***!
