Spraybar in Super Vic + another plate
Also, whose carb plate would you all use for up to a 250 hit?
Also you can run a Y after the regulator on your dedicated and run both systems off the dedicated fuel cell. Im not sure on other's but ours will support 800hp and would handle the two stages flawlessly. Just an idea Im not sure why you were wanting to pull off of the rail.
We have a few plates that will work including a two stage plate. Without knowing any more about your goals or car, the gemini twin works pretty dang well for most users. It comes in a 100-500hp setup adjustable in 100hp increments, or a 50-300hp in 50hp increments. Here is a link:
http://www.nitrousexpress.com/produc...ils.php?id=579
Would be better if you added another regulator on the dedicated. One for each stage.
Again tho two regulators would work better.
One Wilson with burst disk, One Zex plate, and the other is getting a NOS Cross Hair. ON the larger power levels the cross Hair will probably work the best.
If you wanted to get really trick with the set up you could send in your intake and I could build you a custom solenoid bracket to tie all the solenoids and both systems into one.
Like already stated above you can use the dedicated to supply both systems but with one regulator you will loose the ability to make fine air fuel changes with regulator adjustment.
The best set up would be a dedicated with duel pumps and regulators but that may be over kill for what you want. We do build them though so just throwing that out there.
Dave
