Need some nitorus help.
. That is not good. We had to shut it down early because that a/f is scary. So the shop thinks that I need a bigger fuel jet. Zex told me to use a 46 nitrous pill and a 28 fuel pill for a 100 shot. What do you think? I have some scans that I can post if necessary but they do not include the a/f ratio. yeah I was told the fuel pill may be to small. I tested the solenoid before I put the lines in and it was spraying fuel and nitrous. I could check it again when I pull the line to change the pill.
It was also suggested that I may need a standalone. If so would a boost pump work? Like this one?
http://www.compperformancegroupstore...Category_Code=
The car made almost 500 rwhp N/A without the nitrous so maybe Im getting close there?
Do you think a dry kit would perform better than a wet one? My injector duty cycle is only at about 68 percent max when running N/A.
Best thing to do is put a fuel psi gauge on it and see what the fuel is doing on motor first and then on the spray.
Not yet but this was my first plan of action. I need to order a few more.
