nitrous problem help.
Old Oct 16, 2010 | 08:09 AM
r572cobra's Avatar
Default nitrous problem help.
383,11.1 motor,th400 4k convertor,9inch 4.10 gear,100 shot ,took 4 degrees of timming of base 27.breaking up bad in high gear.11.33 at 121,any help would be greatly appreciated.
Old Oct 16, 2010 | 09:44 AM
r572cobra's Avatar
anybody,please help!
Old Oct 16, 2010 | 03:40 PM
r572cobra's Avatar
45 views nobody has a opinion.I thought this was the place to go for advice.
Old Oct 16, 2010 | 04:04 PM
ryarbrough's Avatar
What does the jetting look like? Plugs?
Old Oct 16, 2010 | 04:44 PM
c6 batmobile's Avatar
what do you mean by breaking up? Are you getting detonation? Sputtering? what?
Old Oct 16, 2010 | 04:49 PM
r572cobra's Avatar
cant tell if it missfiring or detonation,52n and 30f jets,plugs look good br8,the discoloration on the ground strap is real close to the base of the plug,ben told it should be in the middle.
Old Oct 16, 2010 | 05:10 PM
If you are detonating you will have black specks on the white porcelain inside the plug. you may need a magnifying glass to see them.
You may have too much timing based on what your saying about your ground strap.
Old Oct 16, 2010 | 05:16 PM
r572cobra's Avatar
will i get a high speed miss,if running too rich.
Old Oct 16, 2010 | 05:24 PM
maybe but it would be more likely if you were lean. An engine tends to be rich on all cylinders not just one. Check all your wires to make sure they are connected well. Did you check all of your plugs to see if they look similar?
Old Oct 16, 2010 | 05:30 PM
ryarbrough's Avatar
Pull 2 more degrees of timing. What does the fuel ring look like?
Old Oct 16, 2010 | 05:31 PM
r572cobra's Avatar
yes,I checked all the plugs,it a ls motor 02 trans am,neever had any problems with the coils,if i pull to much timming that will just make the motor lazy,it wont hurt it,right.
Old Oct 16, 2010 | 05:33 PM
r572cobra's Avatar
fuel ring is not even all the way around.
Old Oct 16, 2010 | 05:35 PM
r572cobra's Avatar
Im running a msd timming twister,has anybody had any problems with these.
Old Oct 16, 2010 | 05:38 PM
ryarbrough's Avatar
Cut the threads off the plugs and look at the base of the porcelain. It should look like someone drew a line around it with a dull pencil. If it's bigger than that it's too rich. If it's skinnier/non-existent it's lean.
Old Oct 16, 2010 | 09:32 PM
r572cobra's Avatar
I will do it tomorrow thanks.
Old Oct 17, 2010 | 12:19 PM
r572cobra's Avatar
ok,cut the plug had a dark brown circle on the bottom of the porcelain.havent figured out how to pos pictures,the thicknes of the circle about 1/8 .
Old Oct 17, 2010 | 12:30 PM
ryarbrough's Avatar
Check all plugs and jet for the leanest plug. Try pulling .002-.003 out of it if that's the leanest plug. 1/8" fuel ring is too much.
Old Oct 17, 2010 | 12:45 PM
1_bad94Camaro's Avatar
Sounds like you need to verify jetting for leanest cylinder and pull some more timing.
Old Oct 17, 2010 | 12:51 PM
r572cobra's Avatar
should the color be a light tan,when the jetting is right on.
Old Oct 17, 2010 | 12:57 PM
yes. it should be light and on the wide side. the thiner it is the leaner it is.
