new pb, video inside
Old Oct 27, 2010 | 02:43 PM
subhumanzz's Avatar
Default new pb, video inside
finally got the car out to MIR to make a 1/4 pass.
patriot stage 2 ls6 heads
233/239 .614/.607 111
100 shot
3600lb race weight
1.397- 60'
in the 2nd run it was running out of bottle.
i put the 57 jet in it which is supposed to be a 125 but i also put in the 31f jet and it ran 11.2 on my wb. i guess i should just step back down to the 28f jet?
http://www.youtube.com/watch_popup?v...&vq=large#t=58
Old Oct 27, 2010 | 05:04 PM
BLK02WS6's Avatar
Looks good - nice run! Did you read any plugs? Can't depend on the wideband alone, but it sounds like it is pretty rich if the 11.2 is accurate...
Also, might wanna try tightening up the front shocks a bit and get that bounce out - it will bring the 60' down some as long as it hooks - you'll have to see what the track will hold...
Old Oct 27, 2010 | 05:05 PM
Chris@NitroDaves
Guest
Posts: n/a
Congrats on the new best...
Old Oct 27, 2010 | 05:06 PM
subhumanzz's Avatar
no i didnt pull any plugs. do you think i should put the 28f back in? im taking it out tomorrow for some testing as long as the weather holds out. honestly even if i did pull the plugs i wouldnt know what i was looking for.
Old Oct 27, 2010 | 05:17 PM
BLK02WS6's Avatar
Time to learn then! There are plenty of posts in this section about plug reading and people on here that can help you. You can't tell what is going on with timing or fueling (by cylinder) unless you read the plugs... logging and wideband readings in conjunction are great (the more data the better), but there is no substitute for plug reading...
The easiest way to do it if you don't have a tow back is to put a couple new plugs and socket/ratchet in your car. When you get through the traps, kill the car from WOT (keep the key turned enough to steer though!). Coast onto the return road and out of the way and swap in a couple new plugs...
If you get a plug reading scope, you don't have to cut them to read them - there are pics in this section showing where the fuel ring is - down inside at the bottom of the porcelain. And the timing mark is easy to see on the strap...
If you are gonna play with nitrous, and want to safely get the most out of it, you really do need to learn now so that when you step it up (and you will step it up), you already have that aspect of tuning under control...
Old Oct 28, 2010 | 02:09 PM
subhumanzz's Avatar
thanks.
heres a go pro video i did also. watch in 1080.
http://www.youtube.com/watch?v=Blbjs...ayer_embedded#!
Old Oct 28, 2010 | 02:25 PM
4U2NV-SS's Avatar
Nice runs and sweet go pro video!!!
What are you running your front shocks at?
Old Oct 28, 2010 | 03:32 PM
z28rob18's Avatar
i cant see the first vid wat were the times?
Old Oct 28, 2010 | 03:58 PM
Chris@NitroDaves
Guest
Posts: n/a
Love the GoPro vid.....
What are the Nitrous kit details??
Old Oct 28, 2010 | 06:48 PM
subhumanzz's Avatar
way to low for this track. in these runs they were on 1. my normal track doesnt hook as well and i didnt adjust them.
10.35@ 129. 1.39- 60'
hsw single nozzle kit jetted for 100.
Old Oct 28, 2010 | 08:03 PM
matt98z's Avatar
lookin good cheeema is that cam spected for a red camero
Old Oct 28, 2010 | 08:50 PM
subhumanzz's Avatar
haha you know it. whats up?
Old Oct 28, 2010 | 09:06 PM
02sleeperz28's Avatar
Very nice. What is your race weight if you don't mind me asking?
Old Oct 29, 2010 | 03:59 AM
subhumanzz's Avatar
Race weight is in the first post. 3600 lbs.
