How much timing to pull for 150-200?
Old Nov 11, 2010 | 10:38 AM
Superman09's Avatar
LS1Tech Sponsor
Default How much timing to pull for 150-200?
What is a rough guess to start on how much timing to pull when spraying 150-200 on a cam only ls1?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 11, 2010 | 11:31 AM
AChotrod's Avatar
6 for a 150, 8 for 200 then read the plugs and adjust from there
Old Nov 11, 2010 | 11:54 AM
ryarbrough's Avatar
I'd start a little more conservatively than that and ramp it in based on what the motor likes.
Old Nov 11, 2010 | 01:36 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Very much agree with this. Especially with the number of users who wont pull the plugs.
Old Nov 11, 2010 | 02:31 PM
Carter01's Avatar
Would also depend on what your na tune is at? I was at 29 degrees on my na tune and pulled 8 for the 150 and it put a good mark on the strap. On a 200 shot I ran 15 and it was about right (#6 being my leanest cylinder, tuning to it) The 2 degrees per 50 is really not safe unless your talking about spraying 100 or so in my opinion. Too little timing never hurt a motor but too much has killed many. Start low and work the timing back in.
Old Nov 11, 2010 | 04:15 PM
SargeZ06's Avatar
^^^^This
Old Nov 11, 2010 | 04:40 PM
Superman09's Avatar
LS1Tech Sponsor
okay thanks guys. What device other than HPtuners hooked to a laptop (something simpler) are you guys using to pull the time so you can run NA with your good timing, and pull to spray?
__________________
Old Nov 11, 2010 | 04:57 PM
Chris@NitroDaves
Guest
Posts: n/a
Other than the doing computer tuning for pulling timing...We have had great results with the Lingenfelter unit http://www.nitrousoutlet.com/catalog...1&product=3467
Old Nov 11, 2010 | 07:51 PM
Superman09's Avatar
LS1Tech Sponsor
So if I want to spray the car, I go to wherever I've mounting this unit and adjust it to pull (X*) for the spray, then go out and give it hell? And when I'm done I just go back and reset the timing back to where it was? How do you pull/reset timing on this module? Thanks!
__________________
Old Nov 11, 2010 | 11:51 PM
Detoxx03's Avatar
I have a MSD Timing Twister on mine
Old Nov 12, 2010 | 01:17 AM
robsquikz28's Avatar
min of 10 degrees depending on the plugs you have.
Old Nov 12, 2010 | 05:52 AM
SargeZ06's Avatar
You can use the "resistor mod" to pull timing only when the nitrous is activated. You can use=r HPTuners to set the value you want pulled then you are done. It will only pull the timing when you flip the arm switch or the noids are activated depending on how you have it wired up.
You won't need to keep going back and changing timing for nitrous and non nitrous tunes. Do a search on "resistor mod".
Old Nov 12, 2010 | 06:55 AM
RsSean's Avatar
could use the dual processor PCM that was onced offered on here somewhere.
Old Nov 12, 2010 | 08:36 AM
Superman09's Avatar
LS1Tech Sponsor
How do like it? How does it work for switching between each set-up? Thanks!
__________________
Old Nov 12, 2010 | 09:30 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
It is the "dialable" resistor mod. You can go from stock timing to 200hp nitrous timing with just the turn of the dial. This is of course assuming your IAT tables in your computer are set up correctly.
Old Nov 12, 2010 | 05:37 PM
Detoxx03's Avatar
I love it. Had it setup when the car was tuned and I don't have to do anything put arm the system and it does its job.
