need help? Plumbing my own nitrous distribution block.
Can it be done with out any special tools. I just need to drill the holes to the desired size and tap them, correct? Here is what im talking about. Whats needed to this correctly. Also I want to run it exactly like this with one solenoid for fuel and n20 to run my direct port.
http://www.nitrousoutlet.com/catalog...8&product=3524
or should I just buy this and run it along the top of the intake and put 1 noid in each inlet and the 16 holes are already plumbed?
http://www.nitrousoutlet.com/catalog...9&product=3792
I would buy the bottom one and then plumb all your lines to that one dist. block. For the price its wise investment. But you will have to make a solid mount for that if your using a hardline kit. It will break the line if you dont from all the moving. Unless your running a soft line then it dont matter.
The rails can be a bit challenging to drill and tap if you have never done it before. However it gives you the ability to lay the system out like you prefer. The distribution block is much easier and faster.
You will need a really good flare tool and bender to do a nice leak free job.
Here is a link to the tools I personaly use.
Tubing bender.
http://www.nitrousoutlet.com/catalog...6&product=2763
Flare Tool
http://www.nitrousoutlet.com/catalog...5&product=2762
Dave
Tubing bender.
Flare Tool
Dave
