A long long time...I used a 1 gallon cell through many many bottles on a 150-200 shot and only used a little bit of fuel each time. Though the fuel will evaporate from sitting.
This is correct. Depending on the shot size it should last anywhere for 3-5 bottles.
I have the Nitrous Outlet platic dedicated fuel cell and its not quite a full gallon, but I get about 2 1/2 bottles out of it with 10lb bottles. I've been spraying a 175 hit.
IT's a simple calculation given a a/f and lb/hr of nitrous used. but for a quick number we use less than 1 gal to feed the motor and nitrous on 1300+ hp. so a itrous only tank should last 5-10 runs easy.
my 1.5 gallin cell lasts a long time. but ive never ran it low enough. i went through 5 gallons in a little over 2 yrs. but it depends on the size shot, fuel psi, a/f ratio, yadda yadda. it lasts a while just top it off after each bottle.
