Fuel Octane VS Shot Size?
What are everyone's thoughts here. My compression is around 11.0-1. I have mahle pistons, callies rods, stock crank, arp bolts and head studs. I have a 347" ls1 w/ stock 243 heads, ls6 intake manifold. Motor was built around nitrous so rings are gapped a little on the larger side.
I was spraying a 150 shot through a single nozzle on 91 octane. I was running 22 degrees max wot timing on this shot.
I now have a plate kit and want to up it to a 200 shot. Can I pull this off with 91 octane? I have HP tuners and can pull as much timing as I want. I had planned to start off at 16 or so. I run the NGK-BR7 plugs gaped to .33.
Where I live 91 is as high as I can get. If I drive 20 miles I can get 94 out of a former BP station. There is a knowledgeable nitrous guy close to me (also a member here) who has said he would help me read the plugs so that will be taken care of.
Thoughts?
Thoughts?
I'm sure you're much more experienced in this, but why go 2-3 steps colder when he's only talking about going from 150-200? I'm in a similar situation as the OP in wanting to go bigger then 150, and it seems like the "basic" nitrous guidelines change a lot when spraying more.
The plugs will not hurt performance so why not be on the safe side?
200 shot on 91oct. is not something I would do a whole lot. That fuel is inconsistant I bet which makes it even worse. If you must do it, be as safe as you can be.
We run C23 and -11 plugs on ANY nitrous tune up on our car.(200 shot on 1st kit)If the cold plugs hurt do you think we would use them? They will allow you to run a little more timing if anything and they pull the heat out of the chamber faster.
I dont know why everyone is so scared of cold plugs? If your spraying then use everything you can to help keep your motor from detonating. All you guys with stock **** need to run a colder plug in #7 and 8 .. hell 2 steps colder if you stepping on the tune up.
Man I need to charge guys for this kind of info. LOL !
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I wouldnt want to tune it for you, I would want to show you how to tune it yourself.
I wont be able to go to the track and help you all the time and when conditions change or you want to go faster why pay someone?
Buy the software and post pics of your plugs, we will get you (and anyone else) dialed in and you will learn along the way.
Man I need to charge guys for this kind of info. LOL !![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
What are the part numbers to the colder plugs? BR8EF is the coldest I've found, is it just BR10EF?
I am really glad you guys are out there getting all your experience and sharing it with the rest of us, I don't post much but I have read a lot your guy's posts and it is very appreciated.
Listen to ATV. He has help me out alot. Im running 9s on a 200 shot now. With no problems with only 16 degress of timming. Yeah its safe but I want that I work and have a family I cant go on the edge just to gain a couple of tenths.
I'm not scared of cold plugs, trust me. I had my first bad nitrous experiences 3-4 years ago when everyone said put TR6s in it, and I came home on a trailer with holes in the motor. Thanks to your and Cam's posting I now run BR8s, and the engine in my car has never been happier. I'm just trying to get as good of an understanding I can, I can't afford another engine.
Tapered seat ....
Nitrous (two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Autolite AR94; Denso IT22 (stock number 5327)
Nitrous (two and a half steps colder)
Heat Range: 8
Gap: Consult
Plug: NGK B8EFS 1049
Nitrous (three steps colder)
Heat Range: 9
Gap: Consult
Plug: NGK B8EFS 1085; Autolite AR93
Nitrous (four steps colder)
Heat Range: 10
Gap: Consult
Plug: NGK R5724-10 (stock number 7993); Autolite AR92
Gasket plug .....
MFG Recommendations: approx 11:1 compression
Heat Range: 8
Gap: Consult ignition mfg.
Plug: NGK R5672A-8 (stock number 7173); Autolite AR3911; Champion C63YC (stock number 796); Denso IQ24 (stock number 5314)
MFG Recommendations: approx 12:1 compression
Heat Range: 9
Plug: NGK R5672A-9 (stock number 7405); Autolite AR3910; Champion C61YC (stock number 785); Denso IQ27 (stock number 5315)
MFG Recommendations: approx 13:1 compression
Heat Range: 9 - 10
Plug: NGK R5671A-9 (stock number 5238); Autolite AR3933; Champion C59CX (stock number 296); Denso IK27 (stock number 5312)
MFG Recommendations: approx 14:1 compression
Heat Range: 10
Plug: NGK R5671A-10 (stock number 5820); Autolite AR3932; Champion C57CX (stock number 295); Denso IK-31 (stock number 5321)
https://ls1tech.com/forums/nitrous-o...o-read-me.html
Heat Range: 7
Gap: Consult
Heat Range: 8
Gap: Consult
Heat Range: 9
Gap: Consult
Heat Range: 10
Gap: Consult
Gasket plug .....
Heat Range: 8
Heat Range: 9
Heat Range: 9 - 10
Heat Range: 10
