Max spray with 243/247 116 lsa cam
I'm finally going to finish off my nitrous system. My cam is ground on the Comp Cams LSL lobes. 243/247 .624/.624 on a 116. I built the motor for boost in the future, so it's only 9.3:1 compression. Probe said my pistons are good up to a 400 shot with the ring gap I have. I've got a Nitrous Outlet spraybar that's rated up to a 300 shot. I may add a second stage. I will be using a dedicated low pressure fuel system for the nitrous. I've got the valvetrain to turn 7500-8000rpm if I wanted to. Can I shoot 300hp total? 400?
Skies the limit. I gotta buddy that put a blower cam in his car so in the future he could put a D1 on his car, and it sucked the nitrous down pretty good. His was only a 150 shot tho. Get it all lined out on the motor first and spray the **** outta it.
