New PB 10.10 at 131 with 1.37 60ft
One my last pass it didn't shift into second. Tried it again on the way home and it won't shift at WOT. Still drive at the moment but I'm going to order a built one asap. I know a ss4000 will put me in the 11's...
Congrats!! Ive gone a bit faster than you NA with a m6. I just added a kit and putting in a th350 over the winter so your times really give me something to shoot for on the bottle. Congrats again that car is moving out!!!!
shortdog Runs good. What size FTI stall is that? From looking at the vid, it looks like 28" tires in the rear.
AChotrod Congrats!! Ive gone a bit faster than you NA with a m6. I just added a kit and putting in a th350 over the winter so your times really give me something to shoot for on the bottle. Congrats again that car is moving out!!!!
BadManLS1 Here is the vid I got!
krissoto Great job, and good luck getting into the 9's. Sounds like you might have it with a lil fine tuning.
You buy this piece, you can ditch the 10 second thoughts on motor and start looking about 9.40, take a little jet away from what you're shooting RIGHT NOW, and still make an 8 second run
I already have a motor sitting here waiting for ya. Shoot me a call when ya get a chance, I want to move this thing and will make it worth your while
I have my setup pretty much sold already but all the money isn't there just yet. I will shoot you a pm... NO problem, that or just give me a ring when ya have a minute. I've got a couple additional parts I'm throwing in with it now, that would probably help ya out some anyway.
Thanks man!
Very tight, low 1.6s on motor, mid 1.3s on the gas. Drives almost like stock on the street. When I first started spraying the car it had 26s and 410s and I couldn't make it through the 1/4. Then i went to 28s and 375s and it made life allot more fun. As far as shift points go, well I only use a Raptor Shift light so I set it at 6400 and by the time I pull the shifter I figure 6500 - 6550. Nitrous window is 3k to 66 so I have to shift it before 6600.
shortdog
Is that 4200 stall setup tight? I figured it'll blow right through unless you're shifting high. It looks like the taller tires helped you gain more mph also.
MATTREDSS Congrats Andy! I def think you will see 9.xxx slip very soon man.
Sofls1 Congrats! Nice Runs!
