plugs for new engine
Old Dec 22, 2010 | 06:14 AM
BradSV8's Avatar
Default plugs for new engine
Hi guys my name is Brad and I am from Australia. I have been reading a lot of info on this site about spark plugs. I have a LS1 with a mid size cam, stock heads and stock bottom end. I have been spraying a 200hp dry shot for the last 4yrs on the TR6 plugs and not had any problems. After reading thru a few threads on here it got me thinking that perhaps I should run a colder plug on my new engine which is LS3. It will be a similar combo to my current LS1 only with a bigger camshaft.
I have run consistant low 10 sec 1/4's with the LS1 setup and I am looking for a 9 sec pass with the new combo. Also the car will be street driven a fair bit as it is 400 km's to my nearest 1/8th and 800 km's to my nearest 1/4. Will I be able to run the colder plugs N/A with out too many problems?
Old Dec 22, 2010 | 06:30 AM
Cold Zero's Avatar
for 200 shot you will need NGK BR8EF ( 4 step colder ) and gap them @ 0.35"
And BTW, any pics or videos of your build ? .. I know Australianz always do it right when in it comes to LSx ENGINES ..
Old Dec 22, 2010 | 10:39 AM
Nitro Dave's Nitrous Outlet's Avatar
With stock compression and displacement you are right on the fine line between BR7EF and BR8EFS plugs. I would start with the 8s and check the plug. If they are showing to be to cold then swap to the 7s.
Dave
Old Dec 22, 2010 | 08:12 PM
BradSV8's Avatar
Thanks guys, will let you know how I get on.
Here is a few pics for you
Not my engine bay this is a mates car but mine is the same setup
dyno sheet
NA pass
http://www.youtube.com/watch?v=SHVBE3GFpaA
N20 pass
http://www.youtube.com/watch?v=sAt1g...eature=related
1/8th mile n20 full street trim
http://s739.photobucket.com/albums/x...vie_0001-1.flv
Old Dec 22, 2010 | 10:25 PM
Caribe's Avatar
Very nice, I try to pick up a copy of "Xtreme Holdens" or "Street Commodores" whenever I pass through Cairns.
Old Dec 23, 2010 | 02:36 PM
Chris@NitroDaves
Guest
Posts: n/a
Nice looking car...It looks like it leaves well.
Old Dec 23, 2010 | 10:22 PM
BradSV8's Avatar
Thanks, it's not too bad off the line best 60 foot is 1.53 so far hoping too get into the 1.4's very soon.
