will a nozzle stop flowing after 150 shot?
Old Dec 23, 2010 | 09:32 AM
a4ls2goat's Avatar
Default will a nozzle stop flowing after 150 shot?
i went from a 150shot to 175 and didn't gain anything.... maybe the Nos Nozzle can't flow more than 150?
Old Dec 23, 2010 | 10:34 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Which nozzle is it?
What did the plugs/wideband say vs the 150 shot?
Mph and DA on both shots?
Also what is the rest of the system? Nozzle isn't necessarily the restriction.
Old Dec 23, 2010 | 11:20 AM
a4ls2goat's Avatar
afs were in between 11.6-11.8....
not sure what nozzle it is...
trap stayed at 124.1mph....
run was 15mins after i had trapped 124mph on the 150hit..
TNT big nitrous solenoid... NOS fuel solenoid...
also, i have a 90* right of the bottle, is this hurting flow?
Old Dec 23, 2010 | 11:28 AM
What jetting were you using for both shots?
The 90* fitting is hurting flow but not at this level. It might take a few hp away but its not going to restrict flow enough to not get 175hp out of it.
Old Dec 23, 2010 | 11:54 AM
a4ls2goat's Avatar
150 was using 62N 32f... than 72n fuel stayed the same..
Old Dec 23, 2010 | 03:23 PM
Chris@NitroDaves
Guest
Posts: n/a
There are nozzles out there that have a max rating of 150hp and wont flow more than that. If you could tell us what nozzle you are using it might help? How big are the lines going from the noids to the nozzle [ A 3an line will flow 175hp ]?
I know our brand and the NX brand nozzles will flow 175+hp with no problems.
Old Dec 23, 2010 | 11:28 PM
a4ls2goat's Avatar
lines are 3an
Old Dec 27, 2010 | 03:51 PM
blue99fbody's Avatar
when i had a nx nozzel kit, they told me i couldnt go over 150 on the 3an so i upgraded to a 4an to spray a 200 shot on a shark nozzel i believe it was and it worked great.
Old Dec 27, 2010 | 10:26 PM
Yes sir!
Im willing to bet that is your issue sir. We call it a SHO hose. Simply a -4an hose that has a -3an end on it. Easy Fix give me a shout on monday. Inventory this week.
By Brett Foote | 2026-06-04 05:00:17
