best kit for 2005 GTO
Old Dec 21, 2010 | 06:23 PM
fatmat80's Avatar
Default best kit for 2005 GTO
I am doing some research on what nitrous kit to purchase. I have a LS2 GTO wih arh headers/mids and magnaflow mufflers. Im currently looking to add a nitrous set-up. I have heard great things about the nano kit as well as the nitro daves kits as well as HSW. Im looking for a 10# plate kit. Any users or sponser feedback would be greatly appreciated.Thanks!!
Old Dec 22, 2010 | 02:18 AM
fatmat80's Avatar
wow 43 views no opinions guys...need help!!!
Old Dec 22, 2010 | 06:20 AM
slammin86's Avatar
There is no best kit.
Old Dec 22, 2010 | 06:27 AM
Cold Zero's Avatar
What size of shot are you looking for ?? ..
Old Dec 22, 2010 | 08:58 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
The best system is really up to you and your personal car.
What are the future goals of the car? Forced induction? Built motor?
Wanting some show factor? Or maybe a a little more stealth for your " competition's of speed on paved road ways"
Old Dec 22, 2010 | 10:24 AM
Nitro Dave's Nitrous Outlet's Avatar
There are many different options on the market when it comes to system styles and brands.
Im obviously partial so Ill let you decide what Brand is best for you. Keep in mind you will need knowledgable customer and tech service after the sale as well.
Is exhaust you only MOd at the time?
What are your future goals with the car?
How much are you looking to spray?
What are your tuning capabilities?
Dave
Old Dec 22, 2010 | 01:36 PM
fatmat80's Avatar
current mods: long tubes and full exhaust, Cold air Intake, tune
Future mods: Heads/Cam?fast 102
I am looking to spray a 150 shot for now. Brand is not really all that important to me as long as the kit is reliable. Would like whatever kit I go with to be compatible with the nano system. Also would prefer plate kit over a nozzle system. I dont plan on pushing more than a 150 shot. I also would like to buy the whole kit from one place.
thanks for your responses so far, please keep them coming.
Old Dec 22, 2010 | 02:08 PM
disc0monkey's Avatar
i would get a dry kit, spray post MAF and a HSW interface. this is the most reliable setup and not too pricey.
personally i would look into NX or daves dry kits and pick up a used HSW interface.
Old Dec 22, 2010 | 03:10 PM
I would rather run a MAF plate then.
http://www.nitrousexpress.com/produc...ils.php?id=763
This would allow you to switch over to a Different size throttle body if you wish. (Such as a 102/102 setup) It also has integrated solenoids which Look very clean and also make install very simple.
This will spray up too 200hp so will still give you some room to grow if you decide to spray more than the sub 150 size shots you have planned now.
This is a wet system, very easy to tune with the stock pcm and hpt or efilive.
Besides online forum support, we also offer a discount. If you are interested or have more questions please feel free to pm or give me a call.
Old Dec 22, 2010 | 05:03 PM
slammin86's Avatar
Personally I would never spray without a wideband, but with this style dry setup a wideband is a MUST
Old Dec 22, 2010 | 05:20 PM
Plug reading sir... Plug reading.
Old Dec 22, 2010 | 05:26 PM
yeah i agree, the interface needs at least a wideband to be tuned.
in the event of electronic failure of the interface, it will not energize the solenoid.
Old Dec 22, 2010 | 06:17 PM
fatmat80's Avatar
thanks guys so far for all the info..looks like I have a little more research to do..I need to research interfaces and fail safes..
Old Dec 22, 2010 | 06:22 PM
slammin86's Avatar
Well that too, but a wideband could save a motor if something strange were to happen during a run and you caught it. It is a nice tool to run all the time anyway.
Old Dec 22, 2010 | 06:52 PM
Evans752's Avatar
I don't run nitrous anymore but IF I WAS GOING TO AGAIN I would get the NOS Noszle Kit (were the bung goes under the injector or plum the intake per cylinder) but they cost I think around $1,200.00 for the kit and you will have to make sure you have the fuel system that can support it. The problem I have seen and had happen to me is when you spray nitrous and fuel into the intakes (wet kits) the fuel has and will puddle up into the intake and backfire and mess the throttle body up, bust intake and more than likely mess COMPLETE MOTOR UP. I had it happen to me 5 1/2 years ago, cost me $6,000.00 and a lot of work changing the motor out of my car, cracked 3 sleeves in factory block, blew back, bottom and lower front of 3 week ould LS6 intake, melted MAF and bent throttle body blade. ONLY way I would is if I was direct port and had it on a button instead of micro switch. NOT TRYING TO TALK YOU OUT OF NITROUS just BE CAREFUL and GOOD LUCK on you decision.
Old Dec 23, 2010 | 09:15 AM
No.
Old Dec 23, 2010 | 09:16 AM
That I agree with. I have one on my car. I just always like to emphasize that it does not replace looking at the plugs.
Old Dec 26, 2010 | 09:31 PM
jamesSS's Avatar
What are you looking for on the plugs? Im gona spray in the spring. Ive heard of it but never new what exactly your looking at when spraying.
Old Dec 27, 2010 | 12:31 AM
fatmat80's Avatar
good question would like to know the answer to this as well..
Old Dec 27, 2010 | 10:31 PM
In a nutshell...
The timing mark on the electrode, the fuel "ring" on the porcelain, signs of detonation, if you have the correct heat range plug, etc
The plugs are the only way to safely tune a nitrous motor.
