Shopping list
Old Jan 27, 2011 | 08:49 PM
ffrh911's Avatar
Default Shopping list
What is needed to run a 150 pill safely?
I know I need
fuel injectors, 42lb?
Fuel pump and hotwire kit, racetronix
plugs, br7efs
bottle with all the lines,
bottle warmer?
Do I need a timing retard kit?
Feel free to add anything
Old Jan 27, 2011 | 08:53 PM
ffrh911's Avatar
What's a good matching cam for this? I wanted to go with something from tsp like the torque v2..
Old Jan 27, 2011 | 09:58 PM
KC&97TA's Avatar
Here's my shopping list, I'm going with a stand alone... keep in mind I'm going to run 2 stages up to 250 and I have a build motor and everything behind the MAF has been upgraded. NO2 is on the back burner since I'm inviolation of 9 of 11 NHRA rules
PM one of the sponsors, they'll get you a list of what you need
98-02 F-body 92mm Plate System, 50-100-150-200Hp Jetting,
I have a dual stage used kit I'm building off of
custom hard lines from noids to plate
Automatic Heated Bottle - I have this already
Nitrous Pressure Gauge - I have this already
Fuel Pressure Safety Switch w/-4 manifold (high pressure)
NHRA Valve male w/pressure disc
180* Blow Down Tube
Purge for 4AN Systems - I have this already
4AN Nitrous Filter
Brand X Single Stage Window Switch
Remote Bottle Opener
F-body Plastic Dedicated Fuel System
Battery Relocation to trunk
Bottle Mounting brackets ?
MSD Timing Twister LS1/6
Progressive controller ?
93-'02 F-Body Ash Tray Switch Panel
Old Jan 27, 2011 | 10:11 PM
ffrh911's Avatar
Whata you think about that nano stuff?
Old Jan 28, 2011 | 12:16 PM
ffrh911's Avatar
Anyone?
Old Jan 28, 2011 | 05:58 PM
singlesupra's Avatar
Originally Posted by ffrh911
Anyone?
Nano seems to be the ****! I have seen big press drops during a run on slightl big shots, even with the bottle heated.
Old Jan 29, 2011 | 02:48 PM
ffrh911's Avatar
Not to knock your help but I need someone to tell me that they've used this and it works great before I buy into a new poduct. Some things dot always spear as they seem...
Thanks for the help tho!
Old Jan 29, 2011 | 02:49 PM
ffrh911's Avatar
I'm thinking about going with nitrous outlets direct port injection kit and bumping it to a 200 shot.
Old Jan 31, 2011 | 09:20 PM
KC&97TA's Avatar
a plate is good for 200... what's done to your motor?
NO2 I think has been best described to me as; a hot chick with an STD, you want to hit it buy you're afraid of what happens, it feels so good you don't want to stop once you do hit it... but sooner or latter you're piston is going to suffer for it if you don't do it right.
Old Feb 6, 2011 | 07:36 PM
BOBS99SS's Avatar
Captain Double Post
^ agree but spray can be very safe ,I have known guys run a 150 shot for years,its just having a safe set up,I would say nitrious is more like coke or herion,after the first time you just want more and more,lol if you can try and limit yourself to what your setup can handle it will be fine,and no I have never did coke or herion lol have seen a lot of friends destroy there lives
Old Feb 7, 2011 | 05:11 PM
Nitro Dave's Nitrous Outlet's Avatar
I know I need
plugs, br7efs
bottle warmer?
What all is done to your car?
You will not need to upgrade injectors if you are going with a wet system. Unless you do not have enough for the motor N/A.
Tell me what your build consist of and Ill respond to the rest.
Dave
