Bottle Valve ?s
Old Feb 1, 2011 | 05:05 PM
Trl_ws6's Avatar
Default Bottle Valve ?s
Well I bought a bottle off a member here and he cant tell me what size everything is so hopefully someone can help me out. Its a Nitrous outlet 15lb bottle and supposedly one of their high flow valves. One side is a gauge and I want to say the first pic is like 8an then in the second pic the fitting on the left is for the nano but what would be the one on the right and teh second pic? Then what would the 8an be for?
Thanks
Old Feb 1, 2011 | 05:43 PM
3rdgen92maro's Avatar
The one on the right in the 2nd pic looks like a -4..its the feedline to the solenoids.
Old Feb 1, 2011 | 09:31 PM
TARZAN's Avatar
It's a burst valve, the large fitting is designed to connect to a blow down tube.
-Will
Old Feb 1, 2011 | 10:55 PM
Trl_ws6's Avatar
Tarzan so the 8an is suppose to be the blow down tube and the opposite one should be the nitrous line and there is a burst valve?
Old Feb 2, 2011 | 07:45 PM
The burst disc is behind the fitting that attaches to the blowdown tube. The fitting screws onto the bottle and basically sandwaches the burst disc between the fitting and bottle.
Old Feb 2, 2011 | 09:46 PM
Trl_ws6's Avatar
So I dont hook up anything to that valve, correct?
Old Feb 2, 2011 | 10:47 PM
Brad@NANO Direct's Avatar
If you choose to run a blow down tube which is recommended, it will attach to the 8 an threads.
Old Feb 3, 2011 | 07:04 AM
This is what you connect to it. In case the bottle pressure gets over 3k psi for some reason it will allow the nitrous evac out of the passenger cabin of the car.
http://www.nitrousoutlet.com/catalog...searchResult=0
Old Feb 3, 2011 | 07:59 AM
I just realized if you plan to use NANO, that valve will not work. Those holes are machined into the chamber of the valve and will not work when using a NANO system. If you plan to use NANO, you will need to purchase a new compatible valve from N20 Outlet or myself.
Old Feb 9, 2011 | 09:20 PM
paint it black vette's Avatar
i just got my nano valve last week. comes with check valve , burst disc with fitting and cap, and bottle nut choice of size 4an or 6an. the real deal.
Old Feb 9, 2011 | 09:59 PM
Trl_ws6's Avatar
Yeah I ordered one. Mine should have arrived today but got delayed.
