Plugs ...
Old Feb 4, 2011 | 01:51 PM
ATVracr's Avatar
Default Plugs ...
I know alot of guys are always asking for pics of plugs ...... I saw this thread on YB that I think would be good for those who are interested....
http://www.yellowbullet.com/forum/sh...d.php?t=330154
Old Feb 4, 2011 | 02:43 PM
Carter01's Avatar
Great Post! For those of you that read this thread you definitely need to read the link as well. Many good posts and if you read things that contradict what you may have learned just look at these guys signatures and see what times they are running.
This post was an eye opener for me:
There is no "ideal" place that the mark should be on the strap. I hear people talk all the time about getting the mark "in the bend". I have seen guys burn their motor down trying to achieve this, all the while not doing what the motor was telling them. The mark needs to be where the motor runs the best, thats it, no other option. I have some motors that like no mark, some half way, some to the bend and some around the bend. As is stated on here all time...every combo is different. Don't be chasing marks, look at mph numbers on et slips.
Monte
Old Feb 4, 2011 | 02:48 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Good Read!!
Old Feb 4, 2011 | 03:42 PM
krissoto's Avatar
I actually read this last night on yb, and just a quick ?, do you guys index your plugs? And Im asking the more serious guys in the nitrous with the bigger shots where tune has to be spot on? Not hijacking just wondering
Old Feb 4, 2011 | 03:47 PM
ATVracr's Avatar
We dont.
Old Feb 4, 2011 | 04:18 PM
SargeZ06's Avatar
Those plugs have to have more than 1 run on them.
Old Feb 4, 2011 | 05:46 PM
ATVracr's Avatar
probably not many...and they did a good job of cuting motor off at the stripe.
Old Feb 4, 2011 | 10:33 PM
03supercobra's Avatar
Good read, some of the best plug pictures I have seen in a while.
Old Feb 5, 2011 | 01:05 AM
Zmg00camaross's Avatar
Thanks ATV good stuff.
Old Feb 5, 2011 | 02:55 AM
cowboysfan's Avatar
this post is going to help me for a long time.
Old Feb 5, 2011 | 04:38 AM
Cam72aro's Avatar
Not really worth the time IMO. I never did it on my s10 with a 406 and a fogger.
Old Feb 5, 2011 | 07:10 AM
Carter01's Avatar
Hum... May i ask what times were you running 1/8 and 1/4, please include mph. Also what was the weight of the truck?
Old Feb 5, 2011 | 07:11 AM
Detroitmuscle's Avatar
oh boy here goes another thread that would be very beneficial to a lot of guys on this site.
Old Feb 5, 2011 | 07:39 AM
Cam72aro's Avatar
5.73 @121 in 1/8 and 8.89 @ 150ish in 1/4 it 60'ed in the 1.28-1.29 range. Weight was 2950lbs with me in it. It isn't cost effective or worth the time when you are pulling plugs every pass and replacing them every 3-5 passes.
Old Feb 5, 2011 | 07:52 AM
Carter01's Avatar
Sounds like you had a great running truck! I guess "to each his own". I have learned how to tune by the fastest guys on tech and this is what works for me and many others. As far as "cost effective or worth the time" I would have to disagree. Yes it is more costly but in order to keep an eye on each cylinder's performance it's the only way. This in turn saves motors and reduces long term costs.
Old Feb 5, 2011 | 08:13 AM
ShiznityZ28's Avatar
The way i see it . We spent $600 on plugs last year sounds expensive but our pistons cost $2k+.... Ill buy the plugs.
Unless you have a great handle on the tune and or widebands in each hole the plugs are very important. We don't pull every plug every run. on a new setup we will ntil we know what holes are hot and cold etc. then we pull those each run and the others once a race day rotating which one each run. we normally look at 3 plugs per run.
Old Feb 5, 2011 | 09:07 AM
Cam72aro's Avatar
My post was towards indexing plugs, not reading them. Thats why I said not worth it if you are pulling them every pass and replacing them after 3-5 runs. You guys jumped the gun on thinking I have no clue about reading plugs. Pulling them is manditory on a big fogger. Sorry for the mix up.
Old Feb 5, 2011 | 09:48 AM
I think you had everyone confused lol we though you were saying that pulling plugs itself was a waste of time. Carry on
Old Feb 5, 2011 | 10:03 AM
Cam72aro's Avatar
My mistake. It was really early when I posted that and meant to quote it. Lol
Old Feb 5, 2011 | 10:42 AM
Carter01's Avatar
What he said^^^
