please help ... FJO Controller wiring
Old Feb 10, 2011 | 05:32 PM
PONTIAC SLP's Avatar
Default please help ... FJO Controller wiring
Hi fellas , I wanna wire the FJO controller but without the the FPSS that shown in the diagram below , how it goes without the FPSS ? , Also i have AEM Fuel pressure gauge and AEM wideband Air Fuel gauge can i connect one of them on the controller ?
please check Diagram below and let me know
and please check if this is correct or not without FPSS , that i edited check diagram below
Attached Thumbnails please help ... FJO Controller wiring-diagram.jpg   please help ... FJO Controller wiring-diagram-2.jpg
Old Feb 11, 2011 | 07:10 PM
anyone can help ?
Old Feb 13, 2011 | 11:00 AM
Tireburnin's Avatar
The second one is correct without a FPSS. The first one is for two systems. I believe you just ground pole 85 from the relay (or both if 2 systems) rather than grounding it through a FPSS. The FPSS basically just breaks the grounds to the the solenoids if pressure drops too low. If you want to go without the FPSS, just ground the relay and there wont be anything to interrupt it.
Old Feb 13, 2011 | 04:04 PM
thanks Sean appreciate your help , i'll go with the second diagram .
Old Feb 18, 2011 | 04:09 PM
Chris@NitroDaves
Guest
Posts: n/a
Second diagram FTW....
Old Feb 19, 2011 | 01:50 AM
thanks bro , but can i connect one of these gauges ( Fuel pressure gauge or wideband Air Fuel gauge instead of FPSS ?
