How much to spray w/ poll????
But you must use caution with nitrous. Start with a small shot, read plugs, make sure everything is ok, then step up to a little higher shot, until you are happy with the results.
Starting with a big shot is a bad idea.
I'd start with a 2-stage setup, 75HP on 1st, 75HP on 2nd
Of course, this is asumming you have all supporting mods, like fuel delivery, correct plugs, retard timing, etc.
Also just for info a 2 stage set up is hard to get set up. First you need to get the 1st stage dialed in then you need to add the 2nd stage but the fuel mix is usually rich when you have 2 different stages going so you have to SOMETIMES lean down the 2nd stage.
This is what I would do I have had everything from NOZZLES to 2 stages now a D.P for NitrousOutlet. I would get your tune right and work your way up to a 200 shot. I would also invest in a standalone fuel cell 200 is to much to pull off the fuel rail. I know people do it but is it worth blown a motor if you have a lean spike.
Hope this helps man good luck
