150 wet shot, what else am I missing?
Nos Sniper EFI kit (comes with WOT switch). $312.25
Nos Bottle heater $75.90
Nos Remote bottle opener $113.75
FPSS $36.90
Gauge $23.99
Nos mini-stage 2- Progressive controller (includes RPM window switch) $220.00
Elebrock nitrous filter $12.95
NGK BR7EF Spark plugs $16.00
Fuel pump ??
Total cost $811.73
FPSS $36.90
Gauge $23.99
Fuel pump ??
Total cost $811.73
Nitrous filter
Controller that pulls timing
Fuel pump (is Walbro the only pump recommended)?
Wideband (this is what I was planning to use) http://cgi.ebay.com/ebaymotors/Bluet...motiveQ5fTools
Thanks.........
Anything else?
Thanks.........
Anything else?
Controller description
Mini 2-Stage Progressive Nitrous Controller.
Nitrous Oxide Systems is proud to announce their new Mini 2 Stage Progressive Nitrous controller. Featuring two completely independent stages of Nitrous control, each with its own throttle position activation switch and progressive ramps. It allows you to get the most out of your Nitrous system and put more power to the ground when traction is at its best. RPM on/off control eliminates the need for a window switch and allows you to turn the Nitrous off and on at set points. It also features two programmable outputs, so you can control timing retard or other devices. With the hand held programmer, it makes programming quick and simple and allows you to mount the main box out of site.
Features
2 fully independent nitrous controllers in one small bulletproof case
Hand held programmer for ease in programming
Allows you to mount the main box out of sight
Integrated throttle position activation switch eliminates the need for a separate WOT switch
Progressive nitrous ramps feature:
a) Delay time programmable from 0 to 9.9 sec.
b) Start percentage programmable from 0 to 99%
c) Ramp time programmable from 0 to 9.9 sec
d) End percentage programmable from 0 to 99%,
e)Nitrous can be programmed to ramp up or down
RPM on/off control eliminates the need for a separate window switch
Solenoid control channels with a 40 amp load capacity for large solenoids
Two output signals for use with timing retards or activation switches
Features
What system would you recommend to pull timing? I looked up systems and what I could find was.......
http://www.jandssafeguard.com/8ChInt...terceptor.html
Really expensive though! Is there something else that is more cost effective?
This will be a street car, track use will be near zero and the system will only be used a few time per year.
This is what I have and it works prefect. And you can find them cheaper then this one i paid $170 brand new for mine http://www.fullthrottlespeed.com/ite...METUNE+eq++Tp+
this is what i use and it works safely every time....
Guest
Posts: n/a
Here is our Brand X total package. It is a complete, safe, and reliable system with all the tech support and trouble shooting you can ask for.
http://www.nitrousoutlet.com/catalog...8&product=3610
The only thing it is lacking is the remote bottle opener. If you are going to order through NOS I do recommend you get the opener similar to ours rather than the solenoid style.
