torque management with nitrous
The simplest way to look a converter stall speed is Power in VS. Resistance out. The more HP ORthe more resistance to move the vehical(weight or gearing) and it will stall higher. Obviously the juice increases HP noticably.
If you would like you can e-mail me your logs if they are hptuners. I'll gladly help you get the car lined out.
To the other guys... I know the converter flashes higher under more power, thats why i am having the issues with the switch. When the nitrous kicks off the converter falls 200-300 rpms then the nitrous kicks back on. I know the problem, just wanted to make sure my solution was safe because i do not want to spray through the shift..
gonna activate the TM to 50% in the mean time.. see im pioneering a new type of drag racing. see how close i can get to 7..35 with the highest trap speed... lol goal is to not get kicked off for no roll bar. 5 point belt, or fire jacket. blah blah blah. pretty funny to launch so easy with m/t and mash it 30' out. was beating up on a procharged mach 1 last week doing this. 588 hp sticker on the hood with supposedly 490ish rwhp..?all while clicking off 8.2's at 92... lol
I then had my 1-2 shift TQ management set at 15%
Then 2-3 shift was set at 10% . That worked well for me ran 9.5 at 149 but multiple 9.6 passes like 60-70 on built 4l60e
I tried with and without and if I had any wheel spin trans would not shift. Then set my TM and even if wheel spin occured it would shift. But my first gear came on quick.
4l60 3600 stall 3.73 gears 27 inch MT drag radial.
