Any of you guys tune for nitrous w/ EFI Live???
I always ran it at 1100-1150.
What does NX reccommend for an EFI system? 1000 PSI?
So your saying that I had too much bottle pressure and leaned it out on the 100 shot (52/33) pill in it at 24 degrees timing?
Looks like I went crazy.
All my old logs were at 1050. I dont know where I came up with 1150 #..
But I must had had the bottle pressure around 1050-1070 on the first nitrous pass and it was ok with the timing in it.
Then I must have put more bottle pressure in it the second nitrous pass and caused it to go lean when my progressive faded to 100%. that would make sense I guess.
I'll turn the heater on and make sure its set to go off at 1050. Guess I had the bottle heater adjusted a little too high. lol
Still plan on taking the MSD timing box off and having seperate nitrous tunes with timing pulled. Unless I switch the PCM down the road.
Yeah. That would be a bit high.
My experiance and from what I've read, it's best around 950-1000. I take mine up to 1050 and purge it, it ends up being about a 1000.
Seperate tunes will ensure that it's timed right. I almost did that but efilive added the pid so I could log what my box pulls.
