HSW Plate flow
Old May 10, 2011 | 04:03 PM
krissoto's Avatar
Default HSW Plate flow
I have a HSW 78mm plate, and I was wanting to turn the kit up some more. I have big NX noids attached to it, wondering if anyone had any luck getting it to flow beyond the 150 hit. I'm looking to go 200-250. Any info is much appreciated
Old May 10, 2011 | 04:24 PM
SuperSlow02's Avatar
Same plate. I've got jets from HSW to 200..so I know that's not a problem. I think a few are at 250. Most say to go DP at that point. So prolly not too many people using a plate that high
Old May 10, 2011 | 04:42 PM
MYSTIC-1SC's Avatar
Put the 200 pills in it and roll homie!
Old May 10, 2011 | 05:58 PM
camscam02's Avatar
There's two different plates, the sudden impact and the brute force
Old May 10, 2011 | 06:46 PM
good info..didnt know the plates were different. I knew the brute force came with the solenoids you can beat somebody to death with....
Old May 10, 2011 | 07:25 PM
krissoto's Avatar
How can I distinguish the difference between the 2 plates
Old May 10, 2011 | 07:34 PM
krissoto's Avatar
I was advised that the plates are the same, the only difference was the noids. I just want to know if it will flow if I put 200-250 jets in there
Old May 10, 2011 | 09:04 PM
If theres no difference. Yes
Old May 10, 2011 | 11:34 PM
repo's Avatar
I wish harris wasn't so vague on this. I have a sudden impact plate also. They say that the plates are not the same. They also say that the bruit force is only available with the kit because of tuning issues with people using the larger plate with incorect noids. I also ordered a .072 n to go in it. as soon as I get the smaller shots hooked up I will put that in and start over with full plug checks to see what is going on. Hasn;t anyone tried it ????????????
Old May 10, 2011 | 11:39 PM
camscam02's Avatar
I have been told they are different as well. If it is the brute force plate I have put an .087 jet through it just fine. And it will flow alot more than that from some things harris has showed me.
Now flowing that much throgh the front of these intakes is your decision
Old May 11, 2011 | 06:40 PM
krissoto's Avatar
So then u think it will be alright to try it out?
Old May 11, 2011 | 07:16 PM
shortdog's Avatar
9 Second Club/Nitrous Mod
You'll be ok. Just make sure you have colder plugs and your timing is down far enough.
Old May 14, 2011 | 07:30 AM
krissoto's Avatar
Anyone have any other input?
Old May 15, 2011 | 12:37 PM
repo's Avatar
If ever quits raining I will let you know how a .072 jet works in my car. Including the fuel jet used.
Old May 15, 2011 | 11:51 PM
LilJayV10's Avatar
That **** cracked me up.
Which one of the two plates are suppose to flow more?
Old Jan 10, 2014 | 02:45 PM
mesterious's Avatar
Bump from the grave. Anyone figure out how to tell the difference between the sudden impact or brute force plate?
Old Jan 10, 2014 | 02:55 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
If it is similiar to ours, you can take it much higher than 150. If you want to be sure you can PM me sizes of the fuel and nitrous holes in the plate, and I can double check on that for you. Let me know if you need any help.
-Garrett
Old Jan 10, 2014 | 05:30 PM
shortdog's Avatar
No difference, just a sales pitch to buy the brute force kit back when they were in business. I still have the sudden impact plate and hitting with well over a 150 shot.
