BS3 used for nitrous
Old May 30, 2011 | 09:50 PM
Martin718's Avatar
Default BS3 used for nitrous
Just set up BS3 on my ls2 nitrous trans am, now I'm looking at how to control the nitrous through the BS3, have any of you had much experience with this or do you recommend just using a separate nitrous controller setup? It's also a multi stage nitrous setup
Thanks for any help
Old May 31, 2011 | 12:36 AM
Graham@NitrousOutlet
Guest
Posts: n/a
What system do you have?
What functions are you looking at doing?
Old May 31, 2011 | 09:12 AM
Martin718's Avatar
I have a beck sheet metal intake that Nitro Dave originally did for a customer for LMR then I picked up the intake before it was used. I'm looking to use the bs3 For controlling the stages of nitrous and separate tune via N/A or Nitrous
Old May 31, 2011 | 04:45 PM
Martin718's Avatar
Guess I should just use the BS3 for the motor and use some type of controller for the nitrous.... Any suggestions on which controller to go with?
Old May 31, 2011 | 08:47 PM
Cliff's Avatar
I have a Harris Speed MicroEdge progressive controller. I like the different setting and things you can do with it. My friend has the BS3 and nitrous with his LS1 and did not have any problems.
Old May 31, 2011 | 10:07 PM
Martin718's Avatar
what is he using to control the nitrous? Is a multiple stage setup?
Old May 31, 2011 | 10:28 PM
Nitro Dave's Nitrous Outlet's Avatar
Martin,
I would love to see installed pics of that intake on your car!
Talk to Brian Black. He has used the BS3 for years. On his car he used a BS3 with a FJO mini to controll it. The BS3 has 3 stage Out puts that will send signal to the solenoids. He used the FJO to be able to progress the solenoids. If using 3 stages You probably do not need to progress but if you do you may want to look at the NOS launcher.
He is now swaping to a new version of BS3 with integrated Nitrous Controlls. So he can give you the in and outs about both set ups.
If you have not already wired it in there are some options that may make everything really easy for you.
Dave
Old May 31, 2011 | 10:49 PM
Martin718's Avatar
How do I get in touch with Brian?
I'll get some pics once it's all cleaned up haha
I haven't started any of the wiring for the nitrous so it'll be great to get the help
I knew it had the outputs and ability for it I just don't know much about it and your correct I won't need a progressive controller if I can activate at least 2 stages off it
Old May 31, 2011 | 11:36 PM
Shoot him a pm.
This is his thread where he is showing off his car.
https://ls1tech.com/forums/nitrous-o...ous-combo.html
Old Jun 1, 2011 | 10:23 AM
ShiznityZ28's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
Martin,
Dave
kinda funny post. LOL
Old Jun 1, 2011 | 10:26 AM
Since its a multi stage setup you don't really need proressive control. youshould see what it takes to get your box updated to the new bs stuff and it should be a decent setup
Old Jun 1, 2011 | 11:25 AM
SMKN TA 95's Avatar
Like Steve said, using 3 stages I don't see the need for a progressive controller setup.
As Dave mentioned above, the standard BS3 setup will control 3 stages of solenoids on a time based setup. Its not actually called a "nitrous" setup, just a boost control system that outputs a ground signal to activate relays for control of solenoids. This would mainly be used for a "wet" setup as there isn't a way for the computer to add fuel for each stage. I've used this in the past and it worked great along with my FJO progressive.
Now, I am testing Big Stuff 3's nitrous control for dry nitrous. It uses the same setup for activating relays via timers and ground signals, but when each stage is turned on it will add the corresponding fuel and pull out the timing you want via a graph/ramp style setup. Very much like the FAST XFI dry setup. I will be testing the COP (Coil on plug) style this weekend for BS3, but I know alot of guys are already using the distributor style BS3 dry setup with success.
Btw, I am the guy that Nitro Dave was referring to a few posts up.
