Help Wiring Window Switch
But then it says if your using a low voltage rpm signal and the signal is not detected to use the the white wire??
Then im sure sure about the others...blue is ground above and below the set window, but no IN the window. And the purple is ground in the window...how do I wire that up? Thanks im still a newbie when it comes to wiring up nitrous. Also dont know how to set the window either?
As far as tach... i would recommend using the white tach wire (should be pin 10) which if im looking at the correct directions would be hooked up the the WHITE wire on the switch. It appears the yellow wire is for hooking to high voltage coil. The white tach wire is easily accessed next to the pcm and easy to run a wire inside the car with the grommet right under the pcm (pcm needs to be removed to access gromet). Believe you need to set the pulse to 2.
12+ volt switched (your nitrous arming button) -> wot switch -> to relay (85/86)side -> window switch which provides the ground.
the 30 and 87 pins on the relay provide the switched power for the solenoids.
blue wire... nope... it does the opposite of the purple wire... would keep something ON when its outside the window.. for example.. if you had your window switch set to spray 3000 rpm to 6000 rpm then that blue wire would keep the ground active from 1000rpm to 2990 rpm and from 6010 rpm+ and blue wire would be OFF from 3000 rpm to 6000 rpm. basically useless for a nitrous app
