Another ring gap question.
Old Jun 23, 2011 | 09:30 PM
SS1875's Avatar
Default Another ring gap question.
As stated, another ring gap question.
Motor Build: 383 stroker, Callies Crank , Manley Rods, JE Pistons.
Fuel: Racetronix 255L Pump, KB BAP, SVO 42# injectors.
top ring is 0.022
end ring is 0.028
oil ring is 3mm
Are these gaps good enough for a 200 wet shot (Nitro Dave's 90mm Plate)???
Old Jun 23, 2011 | 11:30 PM
99slobird's Avatar
top ring is 0.022
end ring is 0.028
oil ring is 3mm
I have similar 383 as yours and wanting to do a 200 shot and what I have gathered from the last few days is there are people spraying 200 plus on stock ls1s and me and you both have a strong bottom end so there shouldn't be any reason why we can't spray a 200 or more but the key is to have enough fuel and the appropriate amount of timing taken out and there isn't a set number on that either. After a 125 or so shot you really need to learn how to read plugs If you already don't to achieve that perfect timing mark....... Help me out Graham am I on the right track or should this fella discard everything I have said????
Old Jun 24, 2011 | 09:41 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Spot on!
200hp is pretty easy with a built bottom end.
The big key like me and 99slobird have talked about, its just taking your time on the tuning and stay conservative on the timing. You are not trying to squeeze every HP out of the combination and set some record. You want it to run well and safe.
Please feel free to contact us with any questions. This includes tuning. I would much rather have you call me and spend some time going over your combination then have you hurt a part.
Old Jun 24, 2011 | 08:53 PM
SS1875's Avatar
I appreciate the info, will probably have Frost do the tune as he did my NA computer. Nitrous tune will be on my spare PCM. If anything arises I will give you a call Graham.
Old Jun 24, 2011 | 09:12 PM
SS1875's Avatar
Frost will probably be doing the tuning for the Nitrous so proper timing shouldn't be an issue. As far as fueling I plan to run a higher octane fuel when spraying just as a procaution. Should have plenty of pump with the Racetronix and BAP combo.....I would hope.
Old Jun 25, 2011 | 08:55 AM
Guest
Posts: n/a
Why dont you give me a basic layout of your setup. Nitrous and fuel wise. I can go over it and give you second pair of eye's if you would like.
What does the car make on motor?
Old Jun 25, 2011 | 03:00 PM
SS1875's Avatar
Fuel: Racetronix 255L with P&P Harness added a KB BAP, 42# SVO injectors, stock lines and rails. Pump gas but would add race gas when using the Nitrous.... wan't to do a 200 shot via your 90mm plate system.
383 stroker as stated before, Callies Crank, Manley Rods, JE Pistons CR 10.92-1.
Car is currently 470hp/440tq NA.
Old Jun 26, 2011 | 11:40 PM
SS1875's Avatar
Bump for Graham @ Nitro Dave's to respond.
Old Jun 27, 2011 | 08:46 AM
Guest
Posts: n/a
If you are putting down that much NA and wanting to go to 200+ then you need to look into a standalone fuel setup on that much power. The pump might handle it but you will be better off with the standalone than mixing in the tank. Also you will have a fuel regulator to make adjustments on as well making the tuning process easier.
Don't even give me till monday?
Old Jun 27, 2011 | 02:20 PM
SS1875's Avatar
Looks like I will have to back off and stay with a smaller shot until I can afford to do a stand alone setup.
Nope gotta know now.. now.. now..
Thanks for the info.
Old Jun 27, 2011 | 03:38 PM
Guest
Posts: n/a
Not a problem man. Let me know if you need anything else.
