Nitrous switch wiring
Where is the right choice to put my switch 12 volt key source and I have them wired together in a pair meaning I y them together
(If its a bad place I hope someone else chimes in.)
https://ls1tech.com/forums/album.php...ictureid=71920
I may be wrong but isn't that post a constant power not switched 12 Volt source?? Not sure what to tell you on the fuses under the hood...I think I looked there and chose my path instead. Guess it depends on how you have things run under the hood as to the best fit in your application.
The fuse blocks we use are in this link.
http://www.nitrousoutlet.com/catalog...26§ion=122
Should I put a fused link into the power wire from the batt to the relay??
