N20 or 243 heads??
Thanks
There are several good company's to deal with. We do a lot of the late model EFI cars.
What is the tale of the tape of the car?
Fuel system? How is it tuned? Bottom end? Goals for the car? What kind of car?
what fuel pump/injectors do you have currently?
if you already have upgraded your fuel pump, i'd go with a HSW 100 shot wet plate kit (90mm $600 or 92mm $650 + COLDER spark plugs).
cnc'd 243 heads would be nice, but they won't put you back in your seat like a 100shot would. however, if you got the heads for a steal and were going to install them yourself, i'd go with the heads. that extra 40 or so horsepower from the heads will always be there.
)Just my plan exactly, when I get some heads on this summer/fall, I'm then upgrading my fuel pump and injectors and prepping for a shot of the juice!
I would do the heads since you have all the supporting mods already. You will ALWAYS have the power. I went with the budget wise mod of spray and love it when i have a full bottle, but its the worst feeling when its empty or you have to go drop another 60 bucks to get it filled.
This guy right here shows what a little tuning and nitrous can do for you on a similar motor combination.
For a wet plate system ( This is what I would recommend. Its all so the same system Carter uses) if the injectors support the motor, you are ok. The nitrous provides it's fuel via the fuel solenoid and adds no further load is applied to the injectors.
Good and broke in and ready for the nitrous.
http://www.nitrousoutlet.com/catalog...3&product=3806
This has all of the safety features you will want other than probably the window switch.
http://www.nitrousoutlet.com/catalog...=26§ion=86
If you do go with nitrous, go with Nitrous Outlet. Great product. Made in America. And the biggest reason is great tech support. Someone always answers when you call or e mail.
As far as this statement goes, keep reading my friend, you will learn....
