should i get my dedicated fuel system first?
Need some help going to be running a direct port 150 shot got stock heads and cam already put some injectors on it and also a fuel pump wanted to know if I should wait to get the fuel system to start spraying or will I be fine till I do gather up the money and buy the nitrous outlet one there selling
Thanks
Thanks
You will be fine if you put a 255 in tank. The fuel system nitrous outlet is great to have to run race fuel in. I've got one and I really like it but I agree it cost a pretty penny.
Guest
Posts: n/a
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
The dedicated has a lot of advantages over just a pump in the tank, but it certianly overkill for the shot size your on now. It would still help and be nice for tuning and safety.
The intake pump with a hotwire is in the 300$ range and a little labor to install.
The stand alone, while still a better way of doing it, is going to be in the 750-900 dollar range. It will be up to you if your car can justify it. If you want to go over the finer advantages of it, let me know sir.
so should i wait till get the fuel system to start spraying or is it fine till then just want to spray it once or twice once for the tune and once to try it out just want to tune everything together since i just put in a cam and a converter or should i just tune the cam and wait on the nitrous till i do get the system
As long as you've upgraded your in tank pump your ok to spray. I've got a 99 ta in my shop that's spraying 150 with stock ls6 heads, tfs cam, fast 90/90 with 28lb injectors on a single 255 walbro. Made 510 with room to play.
