100 shot on a bolt on tune.
Hey guys so i running a bolt on tune in my car and decided to add a 100 wet shot. Now i have no idea what the timing is set at i did try to contact the person who did the mail tune to no avail. Anyhow i set the twister to pull 6* the car didnt feel right so then i tried 5. felt better should i pull 4* ? I changed my plugs to br7 yesterday if that matters.
I'm in the exact same boat. No clue if the timing was changed or not, and if it was, to what degree. I got the HSW Interface controller, and looking at the manual, it looks like the max it will pull is 3 degrees. I'm hoping that will put me back to stock timing, or maybe a degree or 2 below. I know a 100 shot is perfectly fine on stock timing.
Graham, what exactly would you look for when inspecting the plugs?
Guest
Posts: n/a
