Less timing, less fuel = more power?
My Trailblazer SS Ls2 only likes between 23-25 degrees NA before any knock with 93 octane. That amount of timing seems to be about the same for many TBSS's, don't know if its the high load/weight or just the LS2 design. At the track it tends to pick up mph the more timing you can throw at it.
So I thought the same would be true for nitrous.....I use to put 116 octane in the stand alone and run 22-23 degrees on 150hp shot. It rarely picked up any knock so I thought it was good. After reading on here I decided to try less timing. Dropped it 18 degrees and guess what? It actually ran the same ET and had a small increase in mph of .3 mph.
I know to dial it in right I need to read the plugs (Br7's). Right now I'm around 11.0 A/F way rich..... so after I lean it out some it should pick up even more power??
Sorry for the long post. Just excited that I'm finally making some progress. Your thoughts/ opinions?
But, I improved my ET and MPH MUCH more than running it richer with more timing.
This has worked on my stock short block LT1 for the last few years.
You should NEVER use the knock sensors for anything, throw them in the trash.
11.0 is real rich, it will pick up for sure when you lean it out.
Get it around 12.5 A/F then put timing back in 1* at a time until the MPH slows down, then back it up 1-2*.
ATV is right. There is never a reason to make a change as large as 5*. If you truly need to make a change that big, you need to figure out how it was you were that far off in the first place.
What system is this and what is the jetting? If you will get some information coming my way I, and the other's here can help you get it close.
Good post. Shows how AFR are just like dyno's. A tuning tool and the actual number means little.
LOL !What do you guys tell customers that dont/cant check plugs on timing?
Just a difference in A/F meters and I'm sure they all have some.
Justin has same FAST xfi as us and he runs a tad richer (.2-.3) A/F wise than we do but the plugs look about the same.... I'm convinced its just diff. in the sensor or sensor placement.
To Pull a lot out of it. Literally I basically advise them to not go past 11.8 on a wideband and I keep ample timing pulled. About all we can do. I would like to push them toward having a shop do it, but lots of shops are getting it wrong because they do not know either.
I completely agree with this. Different sensors, placement, usage on the sensor, gauges, fuels, etc.
Guess its better than them blaming you when it blows up. LOL !
So if you where running 12.8 AFR and 28 degrees timing N/A. Youd want to richen up to 11.8 and pull timing towards 26 degrees max for a 50 shot, 24 degrees for 100 shot, 22 degrees for a 150 shot?
Agreed. Graham- I just installed a stand alone set at 55psi 116 octane. HSW plate with 62/34 jets. A/F was 10.8 -11.0 last time at the track.
I tried a 33 fuel jet on the street and A/F leaned to around 11.4 So I think next step is pull more timing and try a 32 jet to get it to about 11.8 ? Then get a plug reading.
I owned an fbody. 2 of them. That's no excuse.
. Im new to the Nitrous game,but i cant wait to put it on my car
