NON-projected Tip Spark Plugs??
Old Aug 4, 2011 | 05:37 PM
223HAWK's Avatar
Default NON-projected Tip Spark Plugs??
Im going to step my shot up to a 175 and my tuner suggested a Non Projected Plug? Stock Bottom End, Cam, 255 pump.. I thought Id ask around and see what everyone thought about them. Also what would be the part number if anyone knows..
Thanks
Joey
Old Aug 4, 2011 | 06:07 PM
krissoto's Avatar
the br7efs stock # 3346 are non proj tip plugs.
Old Aug 4, 2011 | 07:59 PM
223HAWK's Avatar
Thanks man! Is this what I should run?
Old Aug 4, 2011 | 08:01 PM
Carter01's Avatar
the #7 is fine for the 150-200 shot, I would go to a number 8 with anything greater than 200.
Old Aug 4, 2011 | 08:22 PM
Detoxx03's Avatar
I ran 8's on mine but 7's should be fine.
Old Aug 4, 2011 | 10:25 PM
h_friesen's Avatar
just put 7s in my car noticed it ran a lil different. is it just me or do the colder plugs make a difference in idle and such?
Old Aug 5, 2011 | 08:47 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Slightly. Usually only when it is cold.
Old Aug 5, 2011 | 09:11 AM
h_friesen's Avatar
Maybe I gapped em wrong? Read on the forums to do at 25
Old Aug 5, 2011 | 09:22 AM
Guest
Posts: n/a
.035 on the gap.
Old Aug 5, 2011 | 11:43 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Agreed, .025" is too tight! .035-.040" would be preferred!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 7, 2011 | 09:27 AM
kidcamaro98's Avatar
I have my br7ef plugs gapped at .032. They have been in my car for 5k and I have yet to foul one. I do alot of stop and go traffic and with the ms3 cam, so its not your ordinary stop and go. I have a good 5+ bottles through them as well. I am going to change them real soon anyways to new br7ef's.
Old Aug 8, 2011 | 09:12 AM
Guest
Posts: n/a
If the tune up is clean at idle and part throttle they will last just fine. Even with the cam. But I do about the same as you. Change them way before I need to so you never have a problem.
Old Aug 8, 2011 | 06:22 PM
for the first few bottles I put through the car, I changed them after every bottle. I was putting new plugs in it every other week. Always checking them after a run to see how they were burning etc. After all that, I stopped doing it and have yet to foul one. I thought I was on the rich side, but I guess not. Im only running 21* of timing too.
Old Aug 9, 2011 | 09:18 AM
Guest
Posts: n/a
The plugs are more resilient than most would give them credit for. I ran mine the same as you do on the street.
Old Aug 14, 2011 | 04:33 PM
Lt1Porsche's Avatar
My car idled funny on the br7ef plugs after normal street use.
Old Aug 15, 2011 | 08:17 PM
Ls1guy98's Avatar
i run them on my car with no adverse reactions whatsoever had the in for 5,000 miles and about 4 bottles. Also put them in a buddies lt1 that i did the nitrous install on, he has had no problems either.
