Plugs after 1st nitrous pull
Old 08-20-2011, 09:34 AM
lncboytre_d's Avatar
Default Plugs after 1st nitrous pull
Here is the plug from bank 1. The car is on a heads and cam tune. I sprayed 50 down the line. Before the pull I installed new BRE7F, let the car idle for about 10 minutes to bring it to 170*, made about a, 1/8 mile pull and immediately cut it off and pulled the #1 plug. There was no timing pulled. Where do I go from here with tuning my car?
Attached Thumbnails Plugs after 1st nitrous pull-2011-08-20-09.00.37.jpg   Plugs after 1st nitrous pull-2011-08-20-08.59.39.jpg   Plugs after 1st nitrous pull-2011-08-20-09.01.07.jpg
Old 08-21-2011, 10:40 PM
cbloveday's Avatar
From what I have read,
you do not want to idle on the plug
you may want to check 7 & 8 plug as they are hotter.
Some good info to read while someone more knowledable responds
http://www.dragstuff.com/techarticle...ark-plugs.html
http://www.4secondsflat.com/plug_chart.html
Old 08-22-2011, 01:17 AM
Thanks, this is all a learning curve for me. Hopefully a successful one.
Old 08-22-2011, 10:21 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Hey Trey,
See how the color is up around the top of the porcelain? That is from all the idling. You can not get a good plug read after letting the plug run for 10 min. We need a fresh plug, burnout, pass, shut it down. Otherwise we might be going off the tuneup at idle or part throttle.
Get us a clean read and we will help get you lined out.
Old 08-22-2011, 11:48 AM
Ok cool, the mallory box will be in tomorrow. I'll put it in, fresh plugs, pull 2° and post pics.
Old 08-22-2011, 11:57 AM
Guest
Posts: n/a
Good deal.
