stock (spray/cam only) lq4 in 1955 chevy
#41
Sweet ride, seen it at Brainerd. I'm not far down the road in Rome, but usually run at Paradise. Gonna try a Carb 6.0 in a Fox body.
You know of any 6.0's for sale in our area?
#42
or you can try car-part.com its a nation wide search of junkyards.
i know bohannon's (just down the street from brainerd dragstrip) has several 6.0s and will sale them for $1200 complete, includes all acess., starter,alt., flexplate, harness and pcm.
#43
http://www.grayandwhite.com/ they have 2 6.0's for $800 each. i think theyre in carrolton, ga. i'm not sure what all comes with them.
I did find one somewhere else with 95k on it for the same price.
Man that 55 is moving.
#44
i also talked to "potts auto salvage" (its above chattanooga). i explained i was wanting to install it in an older car and would need everything. he also told me $1200. i'm not sure on the mileage.
thanks, you have the green nova?
#46
i remember a car club from rome "street knights", back in the 90s. buick bob had a couple 70-72 gs' a riviera and a gn. saw a green nova at a car show last year from rome. had a street knights" tag on it.
#49
I love me some double nickles. One of the guys I grew up with has a '90 chevy truck green fiffty five that runs 10's and looks killer.
I love your project and seeing those numbers on a stock 6.0 makes me feel good about what my 6.0 300zx is going to run. Here is what I think you need and it should only run you about 8 or 9 hundred bucks. Call Calvert and get some call tracks with the split rear springs and a set of rear leaf spring sliders with the bearings from Jegs and your car will launch straight as and arrow with both wheels the same and better 60 foot times. We have run that set up on many cars and have seen as quick as 1.21 60's with street tires. Here is a car I wired and did the brake lines in stainless on. It has the caltrack set up and runs 9.60's on a small block chevy all motor 421.
http://www.nmcadigital.com/forums/sh...ad.php?t=14622
#54
#58
![](http://i808.photobucket.com/albums/zz3/lt1racing/hoseclamps001.jpg)
#59
![](http://i808.photobucket.com/albums/zz3/lt1racing/hoseclamps002.jpg)
difference in parts store clamp and clamp i'm using.
nowhere near as good as fittings. but, i havent had any failures either.
also, throttle body is stock 01 (cable style). intake is also an 01 stock truck intake.
