Nitrous + My Cam = BOOM
-note-
My car would be running today if I ran 100, try to learn from me. Gas is important
Not trying to be an ***, but one part of a cams numbers dont dictate everything about it. We did a cam with a 110 LSA, that made 419 rwhp with stock heads, at 6250 rpm. Not exaclty a high rpm screamer
That cam will peak around 6000-6100 on the motor if its install about 4 degrees advanced, couple hundred later if straight up.
Tight LSA does make some more cylinder pressure, which can be compounded with nitrous use.
Cam spec are in sig
The only negative to your cam is the overlap/ higher cylinder pressures, which is one reason why I chose not to spray on my 230/224 cam. You should be able to spray a 150shot all day long.
