Do I need a fuel pump to spray 150?
I have a new stock fuel pump in my car. The car runs 12.6:1 afr @wot. I have a harris speed works 78mm plate on it. I'm either gonna buy a fuel pump or a timing controller for the kit. I can use efi live to retard the timing if I don't have the controller but I would have to change it all the time. So can the stock fuel pump flow enough to keep up with 150 without leaning out the afr?
cam milled heads all bolts. i just ordered a pump from texas speed. thanks guys for the input i would rather be safe than sorry. only got about 2000mi on motor
