Colder than a 9
Old Sep 29, 2011 | 08:35 AM
Roger Blackmore's Avatar
Default Colder than a 9
I can't seem to find a plug colder than a b9efs. Does NGK make a b10efs? I've got a couple of lean cylinders that I'd like to put a colder plug in.
Old Sep 29, 2011 | 08:36 AM
If they make the plug, what is the stocking number?
Thanks,
Roger
Old Sep 29, 2011 | 08:41 AM
ATVracr's Avatar
We run the R5671a-11
Old Sep 29, 2011 | 08:48 AM
Will that plug work in a cathedral head?
Old Sep 29, 2011 | 08:54 AM
ATVracr's Avatar
Its a gasket seat so not sure it will work on stock head.
Old Sep 29, 2011 | 08:56 AM
ATVracr's Avatar
Nitrous (three steps colder)
Heat Range: 9
Gap: Consult
Plug: NGK B8EFS 1085; Autolite AR93
Nitrous (four steps colder)
Heat Range: 10
Gap: Consult
Plug: NGK R5724-10 (stock number 7993); Autolite AR92
Old Sep 29, 2011 | 09:03 AM
No, it needs to be a tapered seat. I wish they were gasket seat ( from heaven ). Lol. Thanks though. Maybe Nitro Dave will chime in.
Old Sep 29, 2011 | 09:20 AM
ATVracr's Avatar
The stuff I posted above is from the sticky at the top and it is the list of plugs for stock heads.
Plug: NGK R5724-10 (stock number 7993) .... is what you need.
Old Sep 29, 2011 | 10:31 AM
Nitro Dave's Nitrous Outlet's Avatar
I just talked to NGK tech. The number ATV listed is a projected tip plug.
The number 9 is the coldest non projected tip plug NGK offers for a tappered seat head.
Brisk offers a step colder than the number 9 NGK. Its a part number G08S and its 10.99 a plug.
Dave
Old Sep 29, 2011 | 10:43 AM
Thanks ATV, and Dave,
I'll stick with the 9 I guess. Dave, it's a 13:1 motor. 500 hp to the wheels through a turbo 350. I'm wanting to het it to work with a 300 shot through one of your plates on a 90/90 intake. You think the 9 is cold enough?
Old Sep 29, 2011 | 11:19 AM
Roger, You are currently doing a 250 correct? How is the coloring on the strap looking? With the compression you are at a 10 plug would be a good start but IM thinking a 9 will be fine.
Run some C-16 or NOS fuel, Be concervative on the timing. Watch the plugs close.
Dave
Old Sep 29, 2011 | 11:20 AM
ATVracr's Avatar
Dave
Good info, someone should change the sticky above. LOL
#9 should be OK on a 300 shot just start with the timing low and creep up on it.
Old Sep 29, 2011 | 11:32 AM
I'm running C-12 in the motor, and C-16 in the dedicated. I will try to get some pics on the 250 and 300 plugs as soon as I get my converter back.
Thanks again guys
Roger
Old Sep 29, 2011 | 12:10 PM
camscam02's Avatar
word of advice. Just run c16 all the way around. It will simple things up a good amount and less chance of error IMO
Old Sep 29, 2011 | 12:24 PM
Yea, my VP dealer at the local track said the same thing. Said it gives a little wider tuning window. I'll give that a try. Thanks Cams.
Old Sep 29, 2011 | 02:22 PM
Roger, Yea you are at the point its not worth chancing it. Put some 116 in it.
Dave
Old Sep 29, 2011 | 02:31 PM
Dave,
You're running the VP C-16 in your's. Correct?
Old Sep 29, 2011 | 02:35 PM
Yes sir, Well Its sonoco. Came from Bobby Joe.
Im making a few changes to my car and it will be out again. Probably a week or two. We may try to go to San Antonio. If you would like to go Ill let you and Mike know when.
Dave
Old Sep 30, 2011 | 05:49 AM
Yea, I'd be interested in going. If my converter is done in time. Lol. Hey Dave,
Does that Sonoco turn your plugs red?
Old Sep 30, 2011 | 06:41 PM
minytrker's Avatar
No, it doesn't. I run same 116 from same supplier.
