Finally got some runs in on a small shot(408 LS3)
Old 10-03-2011, 08:46 PM
thedudeZ's Avatar
Also if it says to richen it up for the nano, and the baseline recommended jetting is already a tad(or alot) rich, couldn't adding the nano and pulling out say 4-6 more degrees of timing make it closer for a starting point?
Can always add the timing back in and be safer with it pulled out and get to play the lean game?
Old 10-03-2011, 09:12 PM
89pigeontoe's Avatar
Doesn't look like its very hot, see if u can rub that color off the strap with your thumb. Can't see the fuel ring but still don't look as if its got a lot of heat in it. Best way to tell how good your fuel is to cut it open.
Old 10-04-2011, 03:51 AM
IH8FORD's Avatar
I'll cut the plugs open tonight.
Old 10-04-2011, 03:52 AM
IH8FORD's Avatar
Originally Posted by thedudeZ
Which plate? Generic calculator I see the smarter guys using says roughly a .034 fuel jet assuming 1000psi bottle pressure which having a .038 fatter jet along with losing bottle pressure would put the screws to your program.
Zex perimeter. accu-fab TB, No filter at the track.
Old 10-04-2011, 06:18 PM
IH8FORD's Avatar
Added videos
pic of the plug
Old 10-04-2011, 06:52 PM
IH8FORD's Avatar
The color did rub off with my thumb
Old 10-04-2011, 07:11 PM
thedudeZ's Avatar
I'm no expert at all. But thats dirty ***** rich.
Old 10-04-2011, 07:56 PM
03supercobra's Avatar
Do these plugs have 0 drive time on them?
Old 10-04-2011, 08:57 PM
How many passes on the plugs? Definitely fat, but u said you had a leaky nano so I would definitely give that some attention. I don't know if its just bc I'm on my phone but it looked like to me on the motor pass it was smokin it was so rich? What are your wideband readings on that. You may just be masking a rich n/a tune?
Old 10-05-2011, 03:54 AM
IH8FORD's Avatar
One pass on the plugs shut it down when I crosses the finish and pulled it, It was rich at idle on motor for the first pass when we swaped in the colder plugs. But AFR was good down the track. On motor the readings were 12.8-13.0 IIRC I think the nano was my biggest issue Im gonna get a new valve and try it again.
Old 10-05-2011, 05:32 AM
Captain Double Post
BOBS99SS's Avatar
bad *** ride man, good work
Old 10-05-2011, 03:30 PM
  #32
IH8FORD's Avatar
Put them in pushed the car to the starting line and shut the car off at the finish and pulled them.
Old 10-05-2011, 05:27 PM
  #33
loosews6's Avatar
where is video at?
Old 10-05-2011, 05:55 PM
  #34
He added em to the first post
Old 10-07-2011, 10:20 AM
  #35
IH8FORD's Avatar
Well I guess I'll be pulling the heads off. I had oil on #3, #7,#8 plugs. The motor has less than 1,000 miles on it. I replaced the valve seals and it stoped smoking and the plugs were dry. No after driving to the track and runnin this past sunday those same cylinders have oil on the plugs again. I assume the valve guides are screwed and causing the seals to wear out really quick.
Old 10-09-2011, 06:53 PM
  #36
JonCR96Z's Avatar
That fuel ring is huge. Get this other **** fixed so we can actually do some tuning on it and it might be really fast.
