fuel pump
Old Oct 25, 2011 | 09:27 PM
soundengineer's Avatar
Originally Posted by n2ols1cam
im hoping between 700-730 rwhp
you are going to need a lot more pump to accomplish that...
once again.. I suggest a double pump like I mentioned in a post above...
Nasty Performance
Stage 3 Street Kit....
Unless of course deatschwerks has some kind of double pump setup...
then its worth looking into that some more...
Old Oct 25, 2011 | 11:08 PM
n2ols1cam's Avatar
Nasty Performance
damn. ill have to save my money a get that setup
Old Oct 26, 2011 | 06:11 AM
Higgs Boson's Avatar
I put down 730 on nitrous and run a Walbro 255, KB BAP that's active only when armed, stock fuel rails/lines/filter, and 42 lb green tops and I had to lean the crap out of it to get it in line.
No fuel issues here.
Old Oct 26, 2011 | 06:16 AM
Key to success...KB BAP.....
Kenny Bell...Boost a pump...
Old Oct 26, 2011 | 09:39 AM
n2ols1cam's Avatar
i have a 36 lb injectors so that should help me out a little bit. a bap just adds voltage to the pump right?
Old Oct 26, 2011 | 11:13 AM
slowpoke96z28's Avatar
IIRC, the KB boost-a-pump lets the voltage regulator in the gen. raise the voltage a few volts. thats why its best used momentarily. modern musclecars in detroit (anyone remember them?) made a thing like it back in the day. depending on the electronics in your car, you may or may not want to go that route. i'd ask the guys in the stereo section to be on the safe side.
Old Oct 26, 2011 | 11:32 AM
n2ols1cam's Avatar
well i have a hot-wire kit so hopefully that will be good enough.
Old Oct 26, 2011 | 03:04 PM
hot wire kit only ensures there is no voltage lost between the generator and fuel pump due to resistance/impedance. its not going to dramatically "increase" the voltage the pump will see. its a great help, but you still have to measure the pump's output based on regular running voltage, not 16-18 volts like some people have recc'd for you. hot-wire + boost-a-pump is the best bet if you aren't planning on changing the pump itself.
Old Oct 26, 2011 | 03:18 PM
n2ols1cam's Avatar
thank you for your help! how much is a bap and are they easy to install? and can you use it with a stock fuel pressure regulator?
Old Oct 27, 2011 | 10:20 AM
BrntWS6's Avatar
Can someone school me on these fuel pumps. I'll probably be pushing around 460-470rwhp when I'm done with everything and I'm not going to be adding ANY more mods to the car. I have 42lb injectors and stock rails. Does this Racetronix kit install inline or drop in the tank? I really don't want to drop my fuel tank if I don't have to and cutting open a trap door isn't an option for me. Can someone tell me what all I need for my HP needs? Thanks!!!
Old Nov 1, 2011 | 11:50 PM
The Racetronix Kit is a Pump and some Wiring..
you have to drop your tank to install it in your existing fuel bucket... it replaces the stock pump.
on a side note..
I actually have one for sale for a 99-02 v8 Fbody that is already assembled in the fuel bucket
I just replaced my Racetronix with a dual pump from Lonnies Performance
